User #12137
![]() Join Date: Apr 2004
plug wires for ram horns and hei dizzy?
seams to me a while back sumbody made a post about plug wires for hei dizzy and ram horns at the time i had nothing with ramhorns on it and well now i do and needin that info but cant find it
![]() thanks ,robb |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: plug wires for ram horns and hei dizzy?
I use 78 Corvette wires. Perfect fit, as the Vettes used ramshorns and HEI.
#3 | |
User #12137
![]() i was thinkin corvette but couldnt remeber the year thanks again |
![]() Join Date: Nov 2002
TX- is that for the stock position for the wires, or the straight boot on the plugs? Thanks.
#5 | |
Active Member
![]() Join Date: Dec 2004
Anybody know the vendor here that sells the mounting brackets for this hei setup? Thanks......Rick
#7 | |
#8 | |
![]() ![]() Join Date: Jan 2005
GMC Pauls sells the manifold heat shields, the plug wire clips that go under the shields, the clips that go on the oil pan, and the clips that go on the back of the block. |
Robb, I used a set for a 75 vette. Here are a couple of pics.
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
why are the passenger side, front 2 wires so long?
Nappa #700254 run them like TX and woodridge says no problems here
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
#12 | |
#13 | |
"Ochre Ogre"
I have run many sets of these wires on various trucks. I usually buy Napa and what I usually find is the shortest wire could be an inch longer and the longer wires are usually an inch or 2 longer than they need to be. But they work and my trucks were beaters. Otherwise custome cut and fit are the way to go for a show truck.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
Blank
the 77 vette came with all the cap and all the wires hidden under stainless steel housings for a clean look. I used the wires and the lower housing from a 76 on my truck and it looks great. I never was a fan of the cover over the dizzy, never put it back on the vette after motor rebuild. I sure you guys can find some pics on the net.
http://www.brcorvetteclub.com/events...Years/1977.htm this is the car 2003 on display in nashville for corvette's 50th I can't find any good pics under the hood. oh yeah and that me havin a ball in the background with the blue shirt
![]() 1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi. 1977 Corvette 350-375hp 4speed, silver show car. 2002 S10 xtreme, work truck 2004.5 VW jetta GLI 1.8T 6speed, weekend warrior. 2013 Audi A3 TDI, the wife's car |
