![]() Join Date: Apr 2004
pressure info needed
When performing a cylinder pressure test. How low is too low? I know that if one cylinder has a lower pressure than the other s that it indicates a problem. But what should the pressures be? 350 motor stock bore/ heads.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
Re: pressure info needed
I'm just looking for a range. I know that compression ratios changed a little through out the years. The block is on a 72 blazer- all stock
150psi+(just a guess on my part) with less than 10% difference in cylinders
It's a catastrophic success.
![]() Join Date: Jan 2003
The main thing is consistency,unless its smoking like a freight train and the rings are shot then check for a closeness between cylinders.Ratios and pressures will vary between engines but shouldnt fluxuate much between cylinders unless theres a problem.
