Late Model Drivetrain Swap
Hey Everyone,
I picked up a wrecked 2003 Chevy Z71 4X4 Pickup today. The truck came equipped with the 5.3L Vortec Motor. My question is: Has anyone tried transplanting a drivetrain of this nature into a blazer before? I am getting ready to start a frame off restification on my 72 4x4 and would really like to make this drivetrain work. Any information you can contribute would be much appreciated.
-Scott- |
Re: Late Model Drivetrain Swap
I am puttting a 5.3 in my 71 but it is a 2wd. If this one goes good I will do my 72 4wd next. So far it seems like a straight forward swap, other than all the wiring.
The motor swap is pretty basic--the wiring and installing a electronic fuel pump---Oxygen sensor on the exhaust. The trans, transfer case, etc. will be a major PITA as the suspension is completely different in the front---. newer chev trucks have torsion rod suspension--independent axles--etc.
Cool purchase!
I'd use only the motor/tranny from the 03. (of course all the electrics needed too) Keep everything else as is by using the appropriate adaptors/modification's. Would make thing's WAY simpler, IMO. |
Slots go on anything!
Would it be better to use the 205 case than the T-case out of the '03? I figured it might be best to use the front section of the exhaust also, to keep it emissions friendly and locate the 02 sensors and all.
1974 Jimmy- 5.3/4L80e/NP241 |
Boosted Member
What about using a 2wd transmission with a divorced NP205? Then you could keep your axles, and the driveshaft will still be on the correct side.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
emissions friendly, i thought one of the best things about our blazers is the fact that in most states they dont need to pass or comply with any emissions/smog laws
![]() Join Date: Mar 2005
I started mine today,im putting a 6.0 auto 2 wheel drive from a 2004 van with 9000 miles,im using a 4wd blazer frame,but im going to stretch it to build a short bed pick up truck,i belive Advance Adaptors sells an adaptor that connect the 4 L80 to the 205 transfer case. Any advice welcome.
