03-08-2006, 09:07 PM | #1 |
master cyl leak
i have brake fluid dripping from between the master cylinder and booster where they mate. is there a gasket or o ring that can be replaced there? none of the parts places seem to have a seal or know where to get one. do i have to buy a rebuild kit to get this seal? this is a 77 half ton.
03-09-2006, 12:54 PM | #2 |
Insert Witty Text Here
Re: master cyl leak
Your master cylinder is bad. You need to rebuild or replace it. I would replace it with an aftermarket new one, but a rebuilt one will be cheaper.
Slonaker |
03-10-2006, 09:17 PM | #3 |
Re: master cyl leak
i believe there is a oring in there i think lmc has some listed in there catalog.
03-12-2006, 07:42 AM | #4 |
Watch out for your cornhole !
Re: master cyl leak
If fluid is leaking from there, the master cylinder is bad. Any parts store will have one on the shelf, cheap.
Change it soon, that brake fluid can get into the booster and ruin it too.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 03-12-2006 at 07:42 AM. |
