Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 03-11-2006, 06:07 PM   #1
ChevyCrazy67
ChevyCrazy67's Avatar
What gets water spots off windshield
I've tried mild cleaners, fast reducer, steel wool soaked in reducer, nothing so far has even touched them. I'm not sure if they are water spots or chemical spots? maybe even calcium hardend water. I do have well water not city. Whatever they are I know they're tough son a guns. I have just about give up hope of getting them off any ideas???????
Kevin
1967 C-10 swb fleetside
1968 C-10 stepside
1999 Z71- sons dd
1999 2wd silverado-my dd
2003 Tahoe- wifes dd
ChevyCrazy67 is offline   Reply With Quote
Old 03-11-2006, 06:18 PM   #2
Bob D
Rolled on Paint Club
Bob D's Avatar
Re: What gets water spots off windshield
Try some Bon ami and water and scrub in a circular fashion without exerting too much pressure. Kinda like waxing the glass.
Bob
Bob D is offline   Reply With Quote
Old 03-11-2006, 06:29 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Before I retired (against my will), I worked for Alcoa, where we created chemicals from alumina. The by-products inevitably ended up on windshields as well as the rest of the vehicle. It was an alkaline-based product, so it would leave spots on everything.
So, I decided to put some Rain-X on my windshield one day and it was only after many failures that I finally hit on what worked for me.
First, clean the windshield with any good window cleaner. Then, go over the entire surface with some 0000 steel wool (4-aught). Then, go over the windshield with window cleaner, again. Then, the steel wool. After that, you good to go to put some Rain-X on it. Hopefully, after you get the Rain-X on the glass, you won't see any more water spots, regardless of the chemistry of the water (hard, soft, whatever).
I've had well water that was sweet and pure. Just a couple hundred feet away was some of the foulest well water you could ask to avoid.....plenty of sulphur and iron, so stink it did. I didn't wash my car with it. But, calcium is an alkaline, so maybe some CLR used sparingly, will help you get rid of the spots. Good luck.
Member Nr. 2770
Old 03-11-2006, 07:00 PM   #4
cdowns
cdowns's Avatar
Bob
yeh what he said// make sure you use ONLY!!!! bonami because other stuff like comet etc will scratch the glass bonami is safe
Old 03-11-2006, 08:27 PM   #5
MrGoodpliers
MrGoodpliers's Avatar
This is great... I was getting ready to ask this question. I was polishing some chrome on the Big Banana (my daughter's name for the yellow suburban), and when I got to the mirrors I noticed some water spots on the mirror side. I wiped it down with my rag full of chrome polish and it came right off! I didn't even use much pressure! I'll give the bonami a try on alllll that glass, but if it doesn't work I'll use the old Napa chome polish
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 03-11-2006, 06:22 PM   #6
lofly'a
lofly'a's Avatar
i bought a 2001 yukon when it was about a year old with this problem on all the glass, and like you i went through a ton of products that claimed to remove water spots. i even bought the glass buffing kit for spots and scratches from the Eastwood Company and that did'nt work either. i finally threw caution to the wind and cracked open my tub of mothers mag and aluminum polish and the results were excellent, but was also a lot of work since i did it by hand (do you realize much glass a yukon has). this stuff is great for a lot of things including polishing unpainted plastic parts, hard rubber that has faded, dash bezels, etc, etc,........
hey, is'nt this site great. you can ask a question and get an answer without someone trying to sell you something (that's probably not what you need anyway).
i guarantee you'll get results, and if you can't find mothers, you can use blue coral or a few others on the market for aluminum. good luck
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 03-11-2006, 09:11 PM   #7
BrianJordan
Iron Thunder
BrianJordan's Avatar
vinegoe works real good
BrianJordan is offline   Reply With Quote
Old 03-11-2006, 09:37 PM   #8
BubbaGreen
Ya...white vinegar and water mixture....or straight white vinegar. just keep it off the paint.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 03-11-2006, 10:27 PM   #9
Fred T
Cantankerous Geezer
Fred T's Avatar
If it's water spots, use vinegar. If you need to, put some on a rag and leave it on the spots to soak. Should come right off without abrasives.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 03-11-2006, 10:45 PM   #10
ChevyCrazy67
Thanks for the replies, man I was just about ready to give it up. I have some mothers mag wheel polish. This is on my wife's tahoe and yeah there's alotta glass on that sucker. I'll try these out and see if it'll cleaner up, and I also wondered if rain x would keep it off once they are clean thanks for the tip chevloray. thanks again guys this place is GREAT!!!!!!!
Kevin
1968 C-10 stepside
1999 Z71- sons dd
Old 03-11-2006, 11:02 PM   #11
rkarr
rkarr's Avatar
Years ago there was a product called "Glass-wax" that was supposed to work wonders.... I've never been able to find any though...
Rain-x will keep it from coming back, as the water won't stay on the glass long enough to dry.
Great post!
Avatar is a pic of "Before"... Just wait..
1969 Fleetside:
Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans.
20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit).
Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all
Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!!
rkarr is offline   Reply With Quote
Old 05-18-2006, 09:22 PM   #12
cliffsta
Stepsides RULE
cliffsta's Avatar
i just used windex.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 08-09-2006, 08:15 PM   #13
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
vinagar and water 50/50 and newspaper
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-11-2006, 09:13 AM   #14
70c10
67-72 Addict!
70c10's Avatar
After reading this thread, I tried my California Customs aluminum rim polish on my rear slider. It worked awesome!!!!!. Got rid of most of the water spots. I need to do it once more.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-16-2006, 11:07 AM   #15
blessthess
blessthess's Avatar
When I owned a detail shop a few years back an employee of mine showed me a trick that worked 100% after he washed the car (we were in a shaded area) and while the car was still wet he used P&S wire wheel cleaner (it is acid based so be careful) sprayed it on and let it set for only 10 secs (do not let it set no longer then that) on a wet windshield hit with the ultra fine steel wool and viola' gone I mean every one the first time
There's only one type of cool in the world and if you have to ask then your not cool
blessthess is offline   Reply With Quote
