03-11-2006, 08:26 PM | #1 |
Chevy Freak
HEI distributor - $30 shipped.
As the title says.
69 GMC SWB, 350 70 Chevy LWB, 350 55 chevy gasser, 461 73 Camaro, 496 67 RS Camaro, 406 64 Chevelle, 588 71 Nova, 565 67 Camaro, 461 |
03-15-2006, 09:57 AM | #2 |
Active Member
Re: HEI distributor - $30 shipped.
Was it working when removed? Is it original GM? Is the shaft tight in the bushings? If the answer is yes to all of the above, I am interested in buying it.
Thanks. |
03-15-2006, 10:08 AM | #3 |
Chevy Freak
It's a GM. It came out of a motor that ran (supposedly). The motor turns over nice and the distributor appears to be in decent shape (so I would believe it to be true). The shaft has the normal slop. I have never found one yet that didn't have any. I usually shim under the gear to take some of it out, but I always leave some play in it. Just let me know. Brian
03-15-2006, 12:07 PM | #4 |
Resident Curmudgeon
Brian if it's the pre-computer version (4 wire), I'll take it.
Jeff
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
03-15-2006, 12:12 PM | #5 |
Chevy Freak
Jeff, I have one that has your name on it. I'll PM you. This one's still for sale if Ndamerau wants it. Just let me know. Thanks. Brian
03-15-2006, 04:27 PM | #6 |
Active Member
I will take it. I'll just add $30 to the MO for the auto linkage that I am also getting from you.
Thanks |
