03-14-2006, 05:22 PM | #1 |
free advice needed: fuel pump
any of you seasoned guys have advice on replacing the stock mechanical fuel pump on a 350? i haven't bought the pump yet, so if there's another good option, please suggest. i'm maintaining the stock tank behind the seat for the time being. anything to watch out for? installation caveats? i have the service manual for instruction, but still soliciting feedback.
thanks, ya'll colin |
03-14-2006, 05:27 PM | #2 |
'69 Step
Re: free advice needed: fuel pump
Stock fuel pumps are easy to replace. I went with an electric one (Holley) with my in-cab tank. If you are looking for theft protection, you can mount a hidden switch in-line, the thief drives about 20 feet and the truck dies...
03-14-2006, 05:33 PM | #3 |
Watch out for your cornhole !
Get you a new, stock type, pump at any parts store and pop it on. It should take 15 minutes or so.
Only caveat is dealing with the pushrod if it falls down. Personally, I use the long bolt trick, it never fails and only takes a minute or two. Andy did a good FAQ on this very subject. You should read it if you have any apprehension.
03-14-2006, 05:37 PM | #4 |
stock fuel pumps are great // not unusual to get 30-40 years out of them //how can you ask for anymore ???
03-14-2006, 05:45 PM | #5 | |
03-14-2006, 07:38 PM | #6 | |
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
03-14-2006, 05:43 PM | #7 |
does the electric one mount in the stock location, or is it inline somewhere?
03-14-2006, 06:50 PM | #8 |
Msgt USAF Ret
One thing I do is turn the engine over so the cam lobe that moves the push rod in and out is on the low side. It makes starting the mount bolts a lot easier. On a stocker an electric pump is a waste of money IMO.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
03-14-2006, 07:04 PM | #9 |
How about a mild build 350? Somewhere between 350 and 400 HP, will a mechanical pump do what I want or do I need an electric pump? Sorry to hijack your thread but this is kinda related.
Drew '71 Chevy 350/TH350 Hugger Orange Currently just a rolling frame, body work soon to follow!!! Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927 Daily Driver: 1997 Chevrolet S-10 with more gears than pistons |
03-14-2006, 07:37 PM | #10 | |
03-15-2006, 04:16 AM | #11 | |
huh ???
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
03-14-2006, 07:15 PM | #12 |
Where's my beer?
Paul How do you make the invisible, visible?.........You take it away. |
03-15-2006, 01:53 PM | #13 |
Ok i thought i would be ok with the mechanical pump as long as I was sticking with a carb and not going EFI but figured i would check with you guys, thanks for the help. It will be awhile before I am putting a fuel pump on though.
03-15-2006, 09:17 PM | #14 |
Mechanical fuel pumps are good. But on my BBC in the 34 years it has been on the road it has eaten 5 mechanical fuel pumps(my dad did 2 and I did 3) in 150,000 miles. If you added an electric fuel pump the long crank starting is gone less wear and tear on starter and engine during cold weather. Since I put the electric on my truck I would not go back. Who needs fuel injection aka tpi when a carb and electric will do the same. just my opinion
yep a electric edelbrock 1791 is $140 bucks but the ease at which it starts is worth it compared to a $40 mech fuel pump.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
03-15-2006, 09:18 PM | #15 |
03-16-2006, 11:36 AM | #16 |
okay, NOW i'm confused.
03-16-2006, 12:00 PM | #17 |
Just Put A Stock Mechanical Pump On It & Forget It. John
03-16-2006, 01:42 PM | #18 | |
If you want to upgrade a bit, there's a middle ground of one of the upgraded mechanical Holly or Edelbrock pumps - they're good for 110 GPH and mount just like a stock mechanical pump. The body rotates to allow positioning of the input/output lines, although the stock hard lines won't line up and you'll need to either put in brass fittings for a soft line or run some braided lines. These pumps are also rebuildable, and I ordered a kit when I bought the pump but it's been 2 years with no trouble at all. For my 1972, I cut the hardline from the tank just after it reaches the frame rail and put in an Aeromotive in-line fuel filter attached to the frame. I then run -6 Areoquip to the pump (3/8 NPT fittings) and up to the carb. This makes for a nice, clean and very maintainable installation. |
03-16-2006, 02:58 PM | #19 |
thanks everyone. i'm just going to stick with stock.
03-16-2006, 09:39 PM | #20 |
I always just use an old hacksaw blade instead of the bolt. A LOT faster...corn
03-16-2006, 10:12 PM | #21 | |
'72 4x4 fireburb
'72 GMC Suburban 4x4 '93 CBR 1000 '83 G20 beater '88 F-150 - for sale |
03-17-2006, 01:10 AM | #22 |
I've found that the AC pumps last longer but cost more than the Carter pumps.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
04-05-2006, 10:18 PM | #23 |
ok, i'm reviving this because of another thought. i just purchased the $12.99 fuel pump from autozone, and got to thinking while i was there. could my fuel problem (see above) be cause by a malfunctioning original fuel cap? it's a '72, so it has all that ECM/smog/fuel return crap, and i wondered if the corroded cap was causing all of this? any thoughts?
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
04-05-2006, 10:35 PM | #24 |
its all about the +6 inches
What was the actual fault? You never mentioned it.
04-06-2006, 12:00 AM | #25 |
it'll run great for about 4 or 5 miles, then dies. a quick look at the clear inline fuel filter and it's empty! usually takes a few hours or overnight before the fuel starts flowin' through again. every time, always the same. 4-5 miles, sputters and dies from fuel starvation. the last few times it happened at the house, so i quickly disconnected the fuel supply line from the fuel pump, and the fuel flows with strong pressure at that point. i also disconnected from the fuel tank and blew out the line in between with an air hose, and nothing was blocked. so, i get good pressure from the tank until the fuel pump. then, if i quickly plug the line back into the pump. viola! i get flow.
i suspect the fuel pump to be the problem. do they go out gradually, or all of a sudden? this started a long time ago, but was never very frequent. now it is. i picked up that fuel pump, a new fuel cap, and ordered a new sending unit just in case. i just wish i knew what was causing it.
