Old 03-16-2006, 05:17 AM   #1
kanuck
3/4 ton front disc/power steering
can any of the components from a 3/4 ton disc brake frame be used to set up a 1/2 ton disc front????
Are the control arms and spindles the same or is everything heavier.
Found a stripped frame with power steering and disc brakes all in place, just cab, motor and front end stripped and gone. Has all 8 lug wheels.
Hagen
'70 Malibu with 383 stroker/T350
'56 SWB Mercury pickup..under construction
'67 Firebird Convertible...all done stock
'70 LWB 350 on propane...beater
'69 LWB 350/T400 body restored
kanuck is offline   Reply With Quote
Old 03-16-2006, 10:21 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 3/4 ton front disc/power steering
springs.. if you don't mind a rougher ride and a very slight lift in front, steering gear box, all lines and hoses, power steering pump...
that's about it
