I am getting ready to do the clean up work on the frame of my 59 GMC. I have a lot of prettying up to do on the camaro subframe and still need to notch the frame. I want to do the work myself on this one but don't really want to buy a plasma cutter.
![]() There has been a lot of torching done before this point and I sure don't want to use that method any more. Any suggestions? As always thanks for you help.
1959 GMC project |
Re: What to hack my frame with????
SAWZALL, I think that is how it is spelt.. Grinders with cutting wheels, Oh I forgot to mention a Circular saw, with a cutting wheel, this works like you wouldnt believe for big stuff.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" Last edited by Bowtie67; 03-17-2006 at 03:34 PM. |
Outlandish Trends - FL
Sawzall is your best bet. But before you start cutting, get a Unibit (step bit) and drill a hole in each corner where the notch will be if you plan to do a bolt-in notch (the square type). This will keep the corners rounded off and prevent the frame from cracking in the corners.
-Bret 67 short-fleet sold! |
Nothing wrong with torching, takes some grinding to clean it up. There's just something about fire that's hard to beat.
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
![]() ![]() Join Date: Feb 2004
Sawzall -- great tool, trims tree limbs, cuts out door casings, makes nice clean straight cuts in steel and other metals. However for non straight cuts in heavy metal --torches are great. My other favorite cutting tools are an air saw and jig saw -- but plasma cutters are nice.
Where's my beer?
Paul How do you make the invisible, visible?.........You take it away. |
a hand held jigsaw is good for irregular shaped cuts if you know how to use them
Thanks guys, I was thinking of the same tools but wasn't sure they were up to the job. I also consitted a hole saw for the c notch. Does this seem like a good idea?
1959 GMC project |
you can try using a holesaw but i haven't had much luck trying to cut out half circles . i'd use the holesaw to start with and get a real nice scored line on the framerail then id change to a jigsaw with a very fine blade(bimetal) to do the final cut use lubrication on the blade and dont try and force it you'll end up wit a nice clean cut
Happy to be here
![]() Join Date: Mar 2000
You need one of these...
Hey PAUL, I' don't see a battery, so wheres the cord???
no votes for the ol bandsaw?
'67 C10 Short Stepside 5.0TPI/700R4 Last edited by CochinoFilipino; 04-04-2006 at 09:49 PM. |
