Old 03-22-2006, 11:44 PM   #1
dinnut
dinnut's Avatar
lifting my 2wd
im trying to lift my 2wd 1972 c10 to gain a little ground clearance.... just so we can go mess around on some local offroad spots. dont really need 4wd just ground clearance where were going.... im gonna put a 3" body lift on it... what else can i do to lift it up a little. coil rear end makes it hard to lift it seems if i had a 73-87 this would be hella easy... please advise
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 03-22-2006, 11:50 PM   #2
Jr_Blazer_Boy
Re: lifting my 2wd
Just for the record, your 3 inch body lift wont do anything for you off road. Hmmmm?? Your frame and everything else will still have the same clearance.
Jr_Blazer_Boy is offline   Reply With Quote
Old 03-23-2006, 12:38 AM   #3
dinnut
dinnut's Avatar
Re: lifting my 2wd
yeah i know but i figure eventually ill be able to fit a little bigger tire any idea on how to get this c10 up in the air a little
70 longbed
496/th400/Ford 9"
Old 03-23-2006, 12:57 AM   #4
mblackburnjr
collector of vintage rust
mblackburnjr's Avatar
Re: lifting my 2wd
Unless you change the coils not much. Maybe air shocks pumped up in 70's fashion. they make a kit to expand coils, we always made our own w/ some big all thread on our derby cars! lol maybe not the best way to go!
mblackburnjr is offline   Reply With Quote
Old 03-23-2006, 01:19 AM   #5
qksilver
Re: lifting my 2wd
I have seen 2 wheel drive lift kits for the 73 and up
the rear would be easy
qksilver is offline   Reply With Quote
Old 03-23-2006, 01:56 AM   #6
dinnut
dinnut's Avatar
Re: lifting my 2wd
if i got some 73+ lifted coils would they fit the front?
70 longbed
496/th400/Ford 9"
Old 03-23-2006, 02:09 AM   #7
Jr_Blazer_Boy
Re: lifting my 2wd
IMOP, I would throw a 4x4 frame under it and leave off the transfercase and take advantage of all the good stuff that you can get for any 4x4 from places like Rancho!
Old 03-23-2006, 08:35 AM   #8
stingray72
Red Headed Step Child
stingray72's Avatar
Re: lifting my 2wd
Damn.. I wanted to lift my 2wd for a while and I never though of that. Hmm... I might keep it and have a project
What does someone think I could get a 4x4 frame for? I suppose afterwards I just start swapping stuff over.
"Dinner, the perfect break between work and drunk"
-Homer Simpson
stingray72 is offline   Reply With Quote
Old 03-23-2006, 11:53 AM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: lifting my 2wd
73 and up front coils will fit
In the rear, you could start with a set of 3/4 ton coil springs. I'd imagine your present coils are somewhat settled, so between that and the heavier new 3/4 ton coils, the rear will likely come up several inches.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
