Where does your exhaust exit?
Due to my air bag settup (tank, valves, and compressor in spare tire location) I am looking for ideas for exhaust exiting in front of rear tires. Does anyone have any cool ideas?
its all about the +6 inches
Re: Where does your exhaust exit?
It's supposed to exit out from under the truck?
![]() ![]() I DON'T recomend it. |
Short, Fleet, Slammed, V8 Club
Mine exit at the far back corners. You cannot see my tailpipes at all (hidden). You maybe could go that route.
Fabricate till you "puke"
After the 50's Flows, over the axle, around the fuel cell & through the rear drop step bumper(He!! YES IT SOUNDS GOOD!)
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 03-24-2006 at 06:38 PM. |
Mine Dumps right after axles.
2006 Titan SE Crew Cab Daily Driver 2005 Mazda Tribute (Wifes car) 1969 C10 SWB 350/3 Fleet "Max" 1969 Chevelle 2 door 350/3 |
Old Skool Club
![]() Join Date: Jun 2001
Right out of the end of the tailpipes....which are dumping right in front of the rear tires. Don't stand there, when I fire it up....you might get a little soot on your britches!!
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Gone Fishing
Mine dumps right before the axle gotta love those 40 series flows
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
i cut holes in the steps on my bed and ran z28 tips thru that. couldnt tell ya how it sounds cause im still runnin open headers. later...
#9 | |
Cause the Chicks DIG IT!!
You got any pics of that? I'm thinking of doing that with my fleetside. I remember seeing an episode of trucks where Stacy put some exhaust tips in that run through the side of the bed. |
18 Till I Die
I had to be different.... 3" Flowmasters into 6" chrome dumps
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
In front of the wheels dual 3" manderl into 3 1/2 tip Super 40's sounds Awesome.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Mario.......have you had your hearing tested lately? My bet is that you have a big amp for the sound system(just so you can hear it when you are really crankin the throttle
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#13 | |
Where's my beer?
BTW, ![]() Board member rtsmith is just over the hill in Spring Grove, he was just asking me yesterday if there was more guys near us, and here you are ![]() ![]() ![]()
Paul How do you make the invisible, visible?.........You take it away. |
ttt
Avatar is a pic of "Before"... Just wait.. ---------------- 1969 Fleetside: Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans. 20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit). Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all ---------------- Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!! ![]() |
