Old 03-24-2006, 06:45 PM   #1
nathan_454
help with console restoration
first of, I searched... couldnt find what im looking for. The center console in my 71 Blazer needs some work... It has developed a crack where the hing attaches. what is the best way to fix it? the consoles are fiberglass correct? should I just fix it with some mat and resin? also what should I use to refinish it? paint? dye? thanx alot guys
nathan_454 is offline   Reply With Quote
Old 03-25-2006, 08:09 AM   #2
nathan_454
Re: help with console restoration
nobody?
Old 03-25-2006, 08:32 AM   #3
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
I have used the resin to patch one before and it worked out good. The only downside is you will loose the texture in that area.
Duplicolor semigloss paint works well also. You can get it at an advane auto parts store.
I learned this from a board member.
Jason
jay_shy is offline   Reply With Quote
Old 03-25-2006, 08:55 AM   #4
nathan_454
yeah thats what i was worried about with losing the texture... could I do the repair on the inside? i guess there would still be a hairline crack visible.... guess ill have to play with it... thans jay_shy... anyone else have any ideas/input?
Old 03-27-2006, 01:27 AM   #5
cogmeyer
New Member
cogmeyer's Avatar
I am fixing up my interior also and just pulled apart my console today. I have some crack there as well, but they are not too bad. I was planning to just use some fiberglass resin on the inside to beef it up a bit.
A friend who is a pretty serious car restorer actually recommends just using autobody paint and a Preval sprayer for most plastic (If you don't have a paint gun). The Preval sprayer is a little disposable pressurized sprayer, sold online and also at Ace h/w. Essentially a rattle can where you can add your own paint.
I happen to have leftover body paint so this is my plan.
cogmeyer is offline   Reply With Quote
Old 03-27-2006, 01:43 AM   #6
nathan_454
yeah i am figuring on doing the repair on the inside. it wont be seen, so no worries. I have a gun so im good there.
Old 03-27-2006, 09:57 AM   #7
CUSTOM/10
CUSTOM/10's Avatar
You'll also start to loose the texture if you don't stip the paint off. Too many layers of paint will fill in the texture. If it's the original paint, acetone will strip it. Disassemble the console, put one piece at a time in a baking pan that's a few inches deep, poor in some acetone and use a small brush to scub it ( Like a fingernail brush ) After it's all stripped make your repairs and repaint it. It will look like new.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 03-27-2006, 09:59 AM   #8
nathan_454
cool, thanx.... are they painted from the factory? its a durable finish whatever it is.
Old 03-27-2006, 12:06 PM   #9
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Here's a link to the Pic's I took while refurbishing my console.
http://public.fotki.com/blazbk/blaze...furbishing_my/
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 03-27-2006, 12:13 PM   #10
nathan_454
so you didnt strip it at all and used dye?
Old 03-27-2006, 12:14 PM   #11
BobbyK
BobbyK's Avatar
Click on the link.
Pic's show what I did and what I used to strip it before painting.
Old 03-27-2006, 12:17 PM   #12
nathan_454
yeah I see it now... the aircraft stripping stuff... thanx alot... very helpful!
Old 03-27-2006, 08:41 PM   #13
cogmeyer
New Member
cogmeyer's Avatar
Thanks guys. Very helpful for me too! -John
Old 03-30-2006, 11:27 AM   #14
Davy
Davy's Avatar
Bobby, you do great work.
Now that it's been a while...have you seen any ill affects from using the aircraft stripper? More specifically, weakening of the fiberglass structure?
Seems like I remember someone saying it might be a concern.
Thanks,
Davy
1970 Blazer CST
Looking for NOS items for my CST restoration.
Davy is offline   Reply With Quote
Old 03-30-2006, 03:05 PM   #15
BobbyK
BobbyK's Avatar
Nope.Been about 2 years now.
The console still looks great,hasn't faded or scratched.
I've used it normally too,meaning I haven't treated it carefully or anything.
Just remember when useing the stripper that you don't leave it on too long.
I let it sit for 30 min. max. Then reapplied as necessary.
Old 03-31-2006, 12:42 AM   #16
Davy
Davy's Avatar
Thanks Bobby. I will be re-doing one very soon.
1970 Blazer CST
Old 04-09-2006, 12:19 AM   #17
cogmeyer
New Member
cogmeyer's Avatar
I tried the Aircraft Paint remover today. Console has is original med blue paint color. 3 applications, total of about 2 hours, and paint wouldn't budge! With hard scrubbing with a vegetable brush was able to see a little of the base, but not much different than hard scrubbing with Simple Green. I don't know how GM applied that blue paint, the stuff is industructable!
I ended up just doing a very light sand and degreaser painting, and parts are looking great.
Old 04-10-2006, 10:09 AM   #18
BobbyK
BobbyK's Avatar
Try laquer thinner,that should get it off.
