Drag Shocks for a 72 C-10?(with 73-87 suspension)
My 72 C-10 has 73-87 front sus. and the 3rd member/leafs out of the same truck. I recently pulled the overload leaf springs out of the rear to set it down an inch or two and make it ride a little softer. However, I discovered that my rear shocks are entirely worn. I want to replace them with a set of 70/30 adjustable drag shocks. Does anyone make them for my application? If not, what has to be modified in order to do so?
Or, can someone else recommend a good shock which will really squat on launch? Thanks!
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
Re: Drag Shocks for a 72 C-10?(with 73-87 suspension)
anyone?
I think the shocks are the same 67-87. Bigjizmal has looked into this and I think you have to fab up a mount so you can use the car type shocks. You might have to check length you should be in the middle of the travel at ride height.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
