03-29-2006, 03:19 AM | #1 |
2wd to 4wd
hey i got a 72 c/10
and i can aquire a k5 blazer rolling chassis can i use my 2wd steering box? with a 4 lift up front do i still have to change the crossmember? do i need a different tranny crossmember for the 4x4 tranny/xcase? thanks super chevy |
03-29-2006, 05:31 AM | #2 |
Re: 2wd to 4wd
You will need a steering gear off of a 4x4. You will also need the trans crossmember and a larger hump for your floor unless you are going to go with a body lift.
03-29-2006, 10:25 AM | #3 |
Re: 2wd to 4wd
You can use the 2wd steering box if you run crossover steering. Where are you located? I have some of the parts like a front axle,driveshafts,
t-case's,ect
01 2500 Duramax,6spd,4x4,Not stock. Estimated 550rwhp/1100rwfp on fuel only. 03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only 67 K10 in many pieces Little Brothers truck 67 K20 Cummins 12V/NV4500/205, D60/Eaton w/ Detroit,37" Xterrains,crossover steering, Future plans,Twins and lots of fuel. |
03-29-2006, 02:10 PM | #4 | |
Re: 2wd to 4wd
I wanted an automatic transmission. I ended up using a th350 and np205 out of a 1972 Blazer. The crossmember and drive shafts are the same. GM made up the differences between tranny/xfer combo lengths by varying the length of the adapter between the two pieces. What I have observed is that if you have a NP205 now, you can use any NP205 and its transmission in place of what you got. This crossmember has NOTHING to do with the 2wd crossmember. I'm not sure because I've never owned a 2wd, but I believe the 2wd frame is different than the 4wd. If the frames are not different the Blazer's crossmember should work. Maybe somebody else who has done this will chime in.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
03-29-2006, 04:27 PM | #5 |
what happened to flint mi
Re: 2wd to 4wd
ask fuel cell guy , or look under the faq section
71 swb 2wd fleet frame off in progress 72 4x4 blazer daily driver 70 olds cutlass s mint condition owned by a grandma 56 gmc 2wd project waitng 97 fiance mobile |
03-29-2006, 11:20 PM | #6 |
Active Member
Re: 2wd to 4wd
I swapped my 2wd to 4X4, check this thread for some Q&A:
http://67-72chevytrucks.com/vboard/s...d.php?t=188520 Max
Never try to teach a pig to sing; it wastes your time and annoys the pig! Gets More Chicks My lugnuts require more torque than your honda makes! 68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4". |
