Copperhead spec sheet!!
Yep, they finally dropped the load, of information that is!! Go to Truckstv.com and you can download the complete materials, parts, and paint code list. No applause, just throw MONEY!!
Later!! |
Re: Copperhead spec sheet!!
This is for the lazy people such as myself who like to see links
![]() http://truckstv.com/news.aspx?iid=2141 |
do you have a spec sheet for the center console that you can email me ? i tried the link and it wont work.
67 is sold
that info has been on the website for quite a while now
![]() Here is the current verison of Stacey Davids page; http://www.staceydavid.com/projects/copperhead.htm SPECIFICATIONS VEHICLE: 1967 Chevy C10, shortbed, fleetside truck ENGINE: GM Performance ZZ572 crate engine 620hp - 750ft/lbs #001 first pre-production engine It was a tremendous honor for me to get my hot little hands on this ground-breaking engine from GM Performance, and to be the first one to show it to the hot rod world. From what I understand Chevy got so many calls after the show aired, that it crashed the phone systems at GM! Is that cool or what? Bottle Blown Racing Custom dual nitrous system. One 150HP system hidden under the intake, one 250HP system on top of intake NOS Plumbing and hardware for nitrous system TRANSMISSION: B&M Turbo 400 w/ 2500 stall torque converter, B&M shifter and linkage OVERDRIVE: Gear Vendors polished aluminum overdrive w/linkage and hardware BRAKES: Baer Eradispeed - front disc brake kit Aerospace Components - rear disc brake kit Pure Choice Motorsports - Stainless steel brake lines, Stainless steel hoses, bulkheads, fittings, etc ABS PowerBrake – Master cylinder and electric-hydraulic brake system EXHAUST: Sanderson – Headers Doug's Headers – Dual electric exhaust cutouts Edelbrock – Stainless steel mufflers Mike's Muffler Shop – Pipe bent and fitted BODY PARTS: Early Classic Enterprises Bed sides, Tail gate, Head gate, Oak bed floor, Aluminum bed strips, Bumpers, Fenders, Hood, Grille, Radiator Support, All trim and hardware PAINT: "Copperhead Metallic" Custom Color created by Stacey David and Ron Payton of PPG View Custom PPG Paint code Paintucation Paint and bodywork by Kevin Tetz GAS TANK: Early Classic Enterprises WHEELS: Colorado Custom – Lazear Front – 17x8 with 4 ½” bs Rear – 17x 9.5 with 5” bs TIRES: Toyo – Proxes ST Front – 255 x 60 R17 Rear – 285 x 60 R 17 DRIVESHAFT: Denny’s Driveshaft Service "Nitrous ready" driveshaft & hardware REAR END: DTS Custom Dana 60 with 35 spline axles 3.73 gears Truetrac posi 5x5 bolt pattern w/ ½” studs FRONT SUSPENSION: Early Classic Enterprises A-arms, bushings, balljoints, 2 ½” drop spindles, 1” drop coil springs, gas shocks, Heavy duty sway bar STEERING: Early Classic Enterprises Quick ratio steering box, Tie rod ends Pitman arm, Idler arm REAR SUSPENSION: Early Classic Enterprises 4” drop springs, Super track bar kit, Gas shocks, Shock re-location kit, Trailing arm bushings, bracing, and u-bolts INTERIOR: Stylin' Concepts - C-5 Corvette seats Katzkin – Custom Upholstry Rod Doors – "Dano" Interior Panels for 67-72 GM trucks No Limit Engineering – Gauge panel and Glove box door Autometer – Carbon fiber Gauges Painless Performance – Wiring harness Ididit – Polished stainless steel steering column and hardware Colorado Customs – Lazear steering wheel Vintage Air – air conditioning system Lokar – Gas pedal and linkage Early Classic Enterprises – Wipers, switches, knobs, vents, visors, mirror Crow Enterprises – 5-point restraint system Year One – Stereo system, Carpet Heavy’s Customs - Custom console by Kevin Lindamood DOORS: Early Classic Enterprises – Glass, Weatherstripping, One piece window kit, Latches & Hardware Watsons Street Works – Power window kit Billet Specialties – Oval side Mirrors with straight arm ENGINE ACCESSORIES; Zoops Products – Polished aluminum brackets and pulleys, P/S pump Tuff Stuff Performance – 100 amp Alternator, high performance Starter Pure Choice Motorsports – Plumbing, hoses, hardware for P/S, A/C, heater, Tranny Cooler, Fuel lines Johnsons Rod Shop – Vintage “top Fuel” Air Cleaner Be Cool – Polished aluminum Radiator Old Air Products – Dual electric fans NOS – nitrous system CHROME PLATING: Advance Plating bumpers, grille, trim, etc. |
![]() Join Date: Feb 2004
Wow, finally his website is back up, I have been trying to go to it and haven't
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
The LuvShack Garage
Yeppers, I was on his site yesterday, wish he would fill in the blanks
Here I thought I was on the ball?! Well, its there for the slow folks like myself I guess.
Wish they'd made a DVD detailing the build.
'67 C10 Short Stepside 5.0TPI/700R4 |
collector of vintage rust
It seems like someone on here had every episode together on dvd and was offering it to board members awhile back.
#10 | |
___________ Greubin '71 C20 custom - GM Crate 350CI/290HP, BTO 700R4 level II, Qjet, and HEI ![]() |
#11 | |
![]() Quote:
2004 Corvette Coupe Black LS1 (daily driver) 1973 Ford Bronco (resto/mod @ 95%) 1991 GMC sportside Pickup Truck, 468c.i.d. ('nuff said) 1997 Ford F150 4.2L 500k+ miles (trash hauler) 2011 Nissan Juke (wife's daily driver) 1943 Ford GPW WWII jeep (waiting its' turn) |
#12 | |
Blank
anyone remember the wood floor having a gas fill where one of the boards opened up?
![]() 1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi. 1977 Corvette 350-375hp 4speed, silver show car. 2002 S10 xtreme, work truck 2004.5 VW jetta GLI 1.8T 6speed, weekend warrior. 2013 Audi A3 TDI, the wife's car |
#14 | |
67 is sold
#15 | |||
Union Electrician
I think the user was moneyguru? they were working on it,but I'm not sure if they ever got it finished.
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
#16 |
The gas door was off a pt cruiser if I remember right
1970 Short Stepside----Process of Restoring 1983 1/2 Silverado |
#17 |
I believe the gas filler was not much more than a marine gas cap drilled through the wood bed.
I've seen the hidden fuel filler thingy that speedracer's talking about... Keep your eye in Classic Trucks magazine, I'm sure I saw it there..
Avatar is a pic of "Before"... Just wait.. ---------------- 1969 Fleetside: Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans. 20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit). Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all ---------------- Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!! ![]() |
#18 |
Just wondering if trucks gave a price tag on that truck or if anyone has figured one out...just wondering but I bet it is a pretty penny
1970 Short Stepside----Process of Restoring 1983 1/2 Silverado Last edited by alf1096; 04-02-2006 at 06:28 PM. |
#19 |
![]() Join Date: Jan 2001
i THINK that this truck is suposed to be at spring carlisle
im pretty sure it was on the mailer i got ill double check tomarrow
2004 Silverado 2500HD Crewcab 4x4 2000 TOYOTA 4RUNNER 1971 CHEYENNE LWB (THE LOVE SHACK) 1967 c-10 lwb (THE FARMERS DAUGHTER) |
#20 |
Does anyone know what kind of headlights were used?
Aaron |
#21 | |
67 is sold
#22 |
that sounds kewl. I know that,previously,when you try to record there was an annoying light-dark problem with the recording. Does recording from the TiVo pose any such problems for the set top units?
#23 |
Active Member
SPEED is doing a mini-marathon of "TRUCKS" today. The first episodes have been of the "Copperhead" chassis build, brakes , tank, hitch and 572 & tranny and O/D install. It's gotta see stuff, even if it is all reruns. The "new" show is too nasty to watch.
#24 | |
67 is sold
#25 |
Wow!! this is an old thread!
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
