Old 04-02-2006, 03:44 PM   #1
g_goble1967
CPP rotors
So I finnaly got my new springs and six lug rotors from CPP. It took a month, and when I finnaly get my stuff I find that there are no bearings on the face of the Earth to fit the rear of the rotors. I can get them that fit the race but not my spindle. The only ones I found that fit my spindle are either 1/16" smaller or 1/16" larger than the race. What do I do? Anyone else have this problem?
g_goble1967 is offline   Reply With Quote
Old 04-02-2006, 04:13 PM   #2
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Re: CPP rotors
Most bearings have two or three different races that will fit, so you may have to go and see if the parts store can find you some that will work.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 04-02-2006, 04:41 PM   #3
mikeoj
Re: CPP rotors
Get hold of CCP and ask em !!
69 Lwb C-10 402/700R4
70 Lwb C-10 250/3pd
Wisc.
mikeoj is offline   Reply With Quote
Old 04-02-2006, 05:45 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: CPP rotors
If you get hung out to dry too long, send them back and order Early Classics 6 lug rotors. They use common 71-87 truck bearings.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-02-2006, 09:17 PM   #5
g_goble1967
Re: CPP rotors
I called CPP and they tried to tell me that something was wrong with my spindles.I couldnt really make them understand my problem.I even went to a bearing warehouse and we tried every bearing known. Is there a big price difference with the Early Classic rotors?
Old 04-02-2006, 09:47 PM   #6
mikeoj
Re: CPP rotors
This might be a dumb question,But, here goes.You are not trying to put rotors on drum brake spindles are you!! If you are,they won't work.You need disc brake spindles!
70 Lwb C-10 250/3pd
Wisc.
Old 04-02-2006, 11:18 PM   #7
shifty
Questionable
shifty's Avatar
Re: CPP rotors
you should have checked the REviews forum - so many people in this forum have gotten screwed by CPP it's not funny. at this point, ECE is a little pricier than some others, but their support is impeccable, they always ship all the parts you need (even pre-bent brake lines) and their support and service is great. i'll hafta second Tx's recommendation.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-03-2006, 05:47 PM   #8
g_goble1967
Re: CPP rotors
No, Im using an 86 frontend crossmember and all
Old 04-04-2006, 06:10 AM   #9
Tx Firefighter
Re: CPP rotors
I suspect you're using light duty spindles on your 86 front end. There were both heavy and light brakes that year. The aftermarket rotors that ECE, CPP, and others sell are for heavy duty brakes only.
If you do have light duty spindles, you're going to have to replace your spindles with heavy duty spindles to make the aftermarket rotors work.
The way to tell is the measure the thickness of your old 86 model rotors. The heavy duty brakes are 1 1/4 inches thick, light duty are 1 inch thick.
Outer wheel bearing for either heavy or light is an 'A3'. Inner bearing for heavy duty brakes is an 'A5', for light duty brakes is an 'A6'. Those numbers cross reference to any common bearing brand sold in any parts store.
