1/2 ton vs. 3/4 ton Booster.
I pulled a 72 3/4 K20 Booster/master/porp. valve intending to use it to convert my 71 c-10 to power, now I find out it fits, but is different. Will it still work properly ? (it's the 11" Delco booster)
1987 GMC heavy half Shortwide-GONE ![]() 1971 LWB 350/350-GONE ![]() 1972 Buick Skylark (80K orig. miles,one family owned) 2002 Currie Phat Flyer (Pit Vehicle) STOLEN ![]() .............................................. |
its all about the +6 inches
Re: 1/2 ton vs. 3/4 ton Booster.
Yes it'll work, and it is a better piece too.
It's a better set up than the single style diaphram 1/2 ton ones.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
Thank's Longhorn Man and Rod.
Looks like it's time to get off the computer and start bleeding some brakes.
#5 | |
'68 C-20 396 CST CC
![]() Join Date: Mar 2005
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES ![]() 01 Jetta Turbo Daily Driver ![]() 84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico ![]() |
#6 | |
![]() Join Date: Feb 2004
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
![]() Join Date: Apr 2000
The outlets for the master ore different on a 1/2 ton and a 3/4 ton. The 1/2 is front to front, rear to rear and the 3/4 is rear to front and front to rear. If you use the 3/4 master and the 3/4 booster you will be OK but you cant use the 1/2 master with the 3/4 booster the rod is a different lenth. If you want a 1/2 master with the same outlets and the correct lenth for the rod you can use a 1977 master. It uses the same lenth rod as the 3/4 Hope that helps and good luck.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
And,I was told it can`t be done.This is what I plan on my shortbed.Are the proportioning valves the same?
