04-04-2006, 12:20 PM | #1 |
79 Ford HP dana 60 front in a 72k5?
Anyone ever put hp 60 in front instead of a chevy 60? I already have a hp 60 and a 14 bolt to swap in my 72, which should I use?
04-04-2006, 12:24 PM | #2 |
SKINNY TIRES RULE!
Re: 79 Ford HP dana 60 front in a 72k5?
Isn't the ford drop is on the other side?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
04-04-2006, 04:14 PM | #3 |
Yes it is on the other side, I would swap the t-case too.
04-04-2006, 04:29 PM | #4 |
SKINNY TIRES RULE!
Sounds like more trouble than it is worth. you'll have issues with the output shaft from the transmission to the t-case. You may also have to alter your rear drive shaft (if the u-joints are different for the ford vs chevy).
I'd just find a chevy axle and make it easier on yourself.
04-04-2006, 05:43 PM | #5 |
I was thinking of doing something along these lines because the newer trans cases are left hand rather than rt on the older stuff a F***front might be the fix. I'd have to be sure, but the rear is a center deal on either (if I am not mistaken) 6.0 motor, 4l60e/x-case and a f*** front axle?! Could be...
04-04-2006, 05:53 PM | #6 |
What is the purpose of this vechicle?
You do know that the 78-79 ford is the most desirable 60 there is because of it's High pinion and spring pirch width? I'm using a ford 205 in my rock buggy that has a Ford HP60. Ford 205's have good components in them: big bearing case, 32 spline front and rear outputs. The drive train in my buggy will be 4.3TBI/SM465/241 Planetaries/Ford 205 |
04-04-2006, 07:30 PM | #7 |
The Blazer King
I am pretty sure VTBLAZER has one in his trail blazer.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
04-05-2006, 06:14 AM | #8 | |
79 HP Dana w/furd 203-205 doubler behind the th-400 |
04-05-2006, 06:19 AM | #9 |
Just in case your wondering why the spring pack is flattened out in the above pic.
I was checking for clearance. |
04-05-2006, 07:42 AM | #10 |
Yes I know that hp 60 is the good one. I already have one sitting in my pole barn. I bought it for SAS on my 97 yukon(never completed). I would have to buy the chevy 60. I also already have a 14 bolt FF with 4.56, detroit, and disc brakes already rebuilt- ready to go (already sitting in rear of yukon). I want to have a daily-driver capable blazer (72) that will see trails, dunes, mud bogs/drags, and sand drags. I just wonder what work is involed with the tranny and t-case issues- the rest of swap is no big deal to me. Is this swap worth it or should I just buy a matching chevy 1 ton set of axles from my bud. They are already 4.56 would have to add detroits and rebuild them?
04-05-2006, 07:47 AM | #11 |
I`d do it.I wish I had one.I have a NP241 LH-drop/NV4500 with under 20,000 miles from my wrecked`95 I`m dying to use.
You could sell it and buy a GM axle.This is the axle used for straight axle conversions on IFS GMs and serious-duty Jeeps.You could go either way.You`re in a good position having it,either way.
