Old 07-26-2002, 10:24 PM   #1
wildmanaaron
Are 67-72 A-Arms All The Same??
Are the A-Arms all the same on 67-72 models? I know that the spindles of course are different on 5 lug and 6 lug trucks, but will the A-Arms off of a drum brake truck work on a disc brake truck??
Also what is the difference between 67-68 Radiator Supports and 69-72 Radiator Supports??
wildmanaaron is offline   Reply With Quote
Old 07-26-2002, 10:27 PM   #2
Blue_71
Bloo
Blue_71's Avatar
im not sure on the a-arms, but i think headlght location is different on the radiator supports
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 07-26-2002, 10:36 PM   #3
HEAVY CHEVY
BOWTIE FOREVER
HEAVY CHEVY's Avatar
YES they will but you need to use the same year ball joints and a-arm bushings on the disc brake ones that you want to use.
Don't know about the other.
69 C-10 SHORT FLEET BED
350 4-BOLT/400 turbo
upper & lower molding
65 IMPALA 2-DR
283/POWERGLIDE
66 IMPALA 2-DR
hopefully 283/350
~ CAMELTOE ROCKS ~
HEAVY CHEVY is offline   Reply With Quote
Old 07-26-2002, 11:39 PM   #4
Low69CST
The steering stops on the a-arms are different form drums to disc trucks. if you put a 71-up spindle on your drum brake a-arms, it will cause your turning radius to be longer. I don't think the change is much though. However, I think early classic 67-70 disc spindles are made to counter act this.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
