Old 04-08-2006, 12:27 AM   #1
phlegm
Still Green but learning
phlegm's Avatar
Dumb Climate Control Question
How do I cut it off. not on low heat not on low cool but OFF it wont cut OFF, Its always blowing air, why wont it cut off. Off OFf OFFFFFF!, lol..... any help will be appreciated I havent cut the air off in a year (since I bought it).
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 04-08-2006, 12:38 AM   #2
Mechdawg
Mechdawg's Avatar
Re: Dumb Climate Control Question
Sounds like you gota bad switch if the fan is still running when off you could replace it. Or until then try to find and pull the fuse or pop the hood and disconnect the wire going to the fan motor.
Mechdawg is offline   Reply With Quote
Old 04-08-2006, 01:06 AM   #3
phlegm
phlegm's Avatar
maybe, but what exactly is Off, there is not an Off posistion that I know of.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 04-08-2006, 08:02 AM   #4
68C15
blood type; Retumbo
68C15's Avatar
moving the lever all the way to the left SHOULD turn the fan off and kind of stop the airflow. now if only there was a way to shut off the coolant flow from the inside without adding another control
68C15 is offline   Reply With Quote
Old 04-08-2006, 10:47 PM   #5
cstanley
cstanley's Avatar
similar problem. mine will go off (i think) but air still gently blows through depending on driving speed. is that the same problem?
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 04-09-2006, 12:56 PM   #6
72armyswbtruck
72armyswbtruck's Avatar
just unplug the darn fan switch plug from the back
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 04-09-2006, 01:27 PM   #7
jhow66
jhow66's Avatar
This is probably your problem:
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
