04-15-2006, 10:31 PM | #1 |
Need a 3/8 NPT temp sender, or am I SOL ???
Putting a newer engine in our 1970, thought I had everything for the swap, but I just noticed that there is no place on the intake to install the 1/2 NPT stock temp sender.
So I have a hole in each head and on on the intake for possible temp sender locaions and all 3 are 3/8 NPT. The only 1/2 NPT hole on the intake is for the heater hose outlet. Is there a 3/8 NPT temp sender that works correctly with the factory temp gauge ??? Thanks.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
04-16-2006, 12:23 AM | #2 |
Questionable
Re: Need a 3/8 NPT temp sender, or am I SOL ???
you should be able to buy an adapter. i have several down in my garage that i got with my SunPro gauge kit - i think they sell a kit too....if nothing else, hit your local hardware store. they will have one.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
04-16-2006, 12:38 AM | #3 |
its all about the +6 inches
Didn't some one on here use a sensor out of a volvo?
04-16-2006, 06:46 AM | #4 |
Watch out for your cornhole !
I don't believe an adapter is a possibility in this case..
The sending unit is larger than the hole he needs to put it into. I have run into this problem before and never found a good solution. Usually, I use the threaded hole in the intake manifold by the thermosta outlet if there is one. One time though, I wound up putting the sender in the thermostat outlet itself. I used an outlet that had a hole for a vacuum switch, which was 1/2 NPT threads. You can buy an outlet like this at any parts store. Ask for an 80's era 305 housing. You guage won't read correctly till the engine is warmed up enough that the thermostat opens though.
04-16-2006, 07:10 AM | #5 |
Now I know I will most likely get slammed here, but I took the drain cock out of the bottom of the radiator and put that size sensor in. Worked for me. I had to do that because I couldn't get the plug out of the side of the head on the engine. I have since replaced that engine and went back to to original location for the sensor. Keep in mine, that was for an after market gauge, but still worked good.
1997 GMC Sierra Ext 1965 Mustang |
04-16-2006, 10:33 AM | #6 |
Please don't tell me I'm SOL ??? Damn, just when you think its going OK....
How could I find something that works, ohm meter and some hot and cold water ??? Have a pic of the intake here : http://67-72chevytrucks.com/vboard/s...d.php?t=196325
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 04-16-2006 at 10:36 AM. |
04-16-2006, 11:24 AM | #7 |
Active Member
Pull the manifold, drill and tap to 1/2"? Waste a set of gaskets, but it's at least on the floor and not in the truck.
Never try to teach a pig to sing; it wastes your time and annoys the pig! Gets More Chicks My lugnuts require more torque than your honda makes! 68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4". |
04-16-2006, 12:21 PM | #8 |
You can pick up a 3/8 sender from the parts store with the correct ohms, I have done it several times with an engine swap
04-16-2006, 12:23 PM | #9 |
kwmech, try to get us an application or part number.
I've taken my multimeter to the parts store before and tested different ones, but never was able to find which one had the proper resistance value and the correct thread size.
04-16-2006, 07:13 PM | #10 |
Cantankerous Geezer
You can use an adapter, but you won't get a good reading. Drilling and tapping can be done with the manifold installed, grease the bit and tap to catch the shavings and use a magnet.
Fred There is no such thing as too much cam...just not enough engine. |
04-16-2006, 11:43 PM | #11 |
I'll bet someone has figured this out, any thoughts ????
04-16-2006, 11:49 PM | #12 |
If I remember I'll get a part number tomorrow.
04-17-2006, 05:20 AM | #13 |
Active Member
I've been thinking about just taking the regular 1/2 inch sensor, and turning it on a lathe and then tapping it to 3/8 inch. I don't know how much metal you can take off the sensor, but a 3/8 inch pipe die slides right past the smaller end of the sensor. There should be enough there that it would'nt damage the sensor. Let me see what I can come up with.
69 GMC 2500 Camper Special 88 S10 Pickup 04 Impala I ship UPS from 24153 |
04-17-2006, 10:06 AM | #14 |
Cantankerous Geezer
FROC - If you have a bad sensor, cut it open and measure the thickness. I doubt if it will work, but you don't know until you try.
04-17-2006, 02:35 PM | #15 |
The info I have gleened from this BB before said to use a sensor from an early '70's Volvo (sorry no P/N ) and that with this sensor, 180 degrees will put the needle in the center of the gauge.
04-17-2006, 04:20 PM | #16 |
I thought I remembered volvo for this.
04-18-2006, 06:09 AM | #17 |
Active Member
Alright, so I went to Advanced Auto and bought them all out of temperature sensors. I ground one down until all the threads were gone. This put it just about right to get it started in the die. I did'nt cut one open, but the threaded end is still wider than the probe end. I don't think it should hurt the sensor.
69 GMC 2500 Camper Special 88 S10 Pickup 04 Impala I ship UPS from 24153 Last edited by EROC; 09-14-2006 at 06:15 AM. |
04-18-2006, 12:26 PM | #18 |
Very nice! I'll bet there are a lot of people who would pay you for that modification, me included.
04-18-2006, 08:50 PM | #19 |
Eroc - that looks really nice, put me in line if you want to make a few more - looks like you bought three, price me one out shipped to 51334 - Thanks
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 04-18-2006 at 08:52 PM. |
04-20-2006, 05:47 AM | #20 |
Active Member
If you guys are interested I can make a few and ship them out. To keep things legal I'll post them on the parts board. If you want one please reply there. How about $25 shipped.
