Questionable
anyone used late modle wipers/squirters/motor assembly in their truck?
just curious - was just talking in chat about the possibility of using this setup on my truck - i hate the current setup with the pump inside the truck, doesn't work anyway, so i really am wanting to go to the JY and try to find the pump and resevoir for water, then use a later model 99+ truck wipers setup (with integrated squirters) and try to figure out the switch and linkage.
just curious - i asked a similar question before, but looking for specific info this time.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
huh ???
Re: anyone used late modle wipers/squirters/motor assembly in their truck?
Hey shifty, I have a pump and resevoir from an 86 K5 blazer in my 72 and it works great...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
Questionable
you using the wipers and squirters also? if yes, can you provide some details on the install and maybe a pic or two?
huh ???
Still have the 72 wipers and squirters. The old pump took a dump years ago and I had the resevoir laying around after we scrapped the 86.I like the 86 resevoir because the pump is made onto it...
Questionable
yeah, that's what i hear. i am going with the same setup, i think you can buy the resevoir and pump new for $50 or so. i'm going to look into that so I can at least get the current pump out from under the dash (unless it's integrated with the wiper motor?). makes more sense to have the resevoir and pump in the same place, not the pump and wiper motor..
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 04-17-2006 at 03:53 PM. |
I'm interested in this as well, mostly the late model wiper motor. My factory motor is toast and if/when I get her back on the raod I may at some point need wipers that work. That is if it ever rains again.
I am stripping and 87 and it has the wiper arm squirters. I did some measuring and it looks like it will all work........so it's going on my 67, the wiper arm assm, motor and linkage
#8 | |
Questionable
when you expect to get this done?
shifty, the motor and pump are integrated into one unit that's a bear to get to. might be best to clip the wires that activate the pump bypassing it to the new pump. i'd also be curious about the pump swap. mine isn't that old, but it sux.
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
Questionable
hmmm, figures, nothing is easy
![]() i guess what i really need to do is hit the local junkyard at this point, eh?
C10 Club Tennessee
shifty,
Do what I did and get the S10 pump and wire it up to your existing wiper switch. If you want more info I can get it to you. Putter was the one who helped me with it. It shoots across the garage!!
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
