Old 07-28-2002, 01:11 PM   #1
kurts72
Help, How To Line Up Bottom A-arms With Frame Member?
Installing my lowering kit and am putting my lower a-arms back on my 1/2 ton 2wd chevy pickup. However, upon tighting my ubolts onto the lower a-arm shaft I realized that I did not measure the location when I removed them. There is a small hole in the shaft....does the u-bolt line up with it?? THANKS FOR THE HELP!
Kurt in Durand, IL
kurts72 is offline   Reply With Quote
Old 07-28-2002, 01:48 PM   #2
Tim Christian
Tim Christian's Avatar
They are two tits that goes in these holes if you are laying under your truck looking up the the tits are in the two little cradles that the U-bolts go through I hope I have not confused you.
Tim Christian is offline   Reply With Quote
Old 07-28-2002, 02:14 PM   #3
kurts72
Thanks Tim! You are right, when you said tits I only thought of the one kind all men think about! I understand what you mean and just turned my shaft around to line up with the front tit in the front saddle. Thanks for the quick response, now I can keep working. Kurt
Kurt in Durand, IL
Old 07-28-2002, 02:37 PM   #4
Tim Christian
Your Welcome Kurt. I have a hard time with words sometimes! LOL
