Old 07-28-2002, 04:19 PM   #1
twomacs4
Wiring - replacing 67 instr panel with later
Picked up a instr. panel to replace the old one in 67.
Came out of 72.
Anyone ever rewired the plug so it will work in 67?
If so do you have a diagram?
twomacs4 is offline   Reply With Quote
Old 07-28-2002, 04:22 PM   #2
68 Stepside
huh?
68 Stepside's Avatar
Do you mean a you're wiring a gauge dash into a truck that didn't have gauges? If so, here you go, this is straight off of GMC Pauls website:
Swapping A Idiot Light Dash Out To Gauge Dash
The following is for a gauge dash this gives the numbered position of the wires in gauge dash and followed by what it supplies, then number from idiot light dash you move wire from.
1-Black with white stripe (alternator) This runs from the 12 R from voltage regulator and should have a inline fuse.
2-Tan (Brake warning light) Original position 2
3-Pink (Fuel Gauge) Original Position 7
4-Tan(Fuel Gauge) Original Position 4
5-Empty(not Used)
6-Dark Green (Temp. Gauge) Original position 5
7-Black(ground)Original Position 6
8-Gray(cluster light feed) Original Position 12
9-Medium Blue (Right turn) Original Position 11
10-Lt. Blue (left turn) Original Position 10
11-Lt. Green (high Beam indicator) Original Position 9
12-Black/w brown stripe use wire ran from the junction block near battery mounted to passenger side fender with a inline fuse located at junction block end.
Remove the wires from your loom plug and place the colors in the # on plug that corresponds with the color from list above. You will need to replace your idiot light temp. gauge for a temp. sending unit with gauges. The black and white wire feeds from the 12gRed wire off back of alternator and requires the use of 2-4amp inline fuses, this wire you need to make and run. The DARK BLUE wire that was originally in #1 position should be deleted because this was the idiot light for the oil pressure. If you need more info. ask.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 07-28-2002, 04:23 PM   #3
68 Stepside
huh?
Here's the gauge connector wiring pic:
RIP El Jay
