Old 07-29-2002, 01:57 PM   #1
dubie
dubie's Avatar
removing door glass
Any tips on removing and replacing the door glass?
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 07-29-2002, 02:08 PM   #2
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
let's see if i can remember this all
remove vent window, 2 screws on front of door, 2 on the side, window needs to be rolled down to do this,
remove weatherstripping from door on sides of window......not sure how to do this without damaging it....
roll the window up partway, slide it foreward to realease it from the back track, roll the window up most of the way, keeping it out of the tracks, then tip it toward to outside of the door, tilt it and pull it off the rollers.......
I hope that's right....i just kinda feel my way around when I'm doing these and it's been a few weeks since I did one.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 07-29-2002, 03:11 PM   #3
Southpa
Southpa's Avatar
I have very recent experience in this matter, so I better explain while its still clear in my head. Roll the main window down all the way and then remove vent window as Buck described. Three screws on the front angled door edge, two large screws holding the bottom. You have to give the vent a 90 degree turn to successfully get it past the window slot when pulling it out.
Then roll the main window up all the way, its easier if you carefully remove the window felts. When the window is up you can see the roller setup. The track that holds the rollers has a small open area where one of the wheels can be lifted out.
Putting the vent windows in is a lot tougher unless you know what to do. Put the main window back in and roll it all the way down. The rear track that guides the main window must be unscrewed. You will find two screws holding the bottom part in and one screw at the top backside of the door. Move the rear track and window as far back as you can. This gives ample clearance for getting the vent in position. Believe me if you don't loosen that rear track you will have a lot of wrestling to do.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 08-02-2003, 01:35 PM   #4
foxyjoe
Thanks for the reply. Apparently I don't have to pull the window glass first - but the vent is still a bugger to get out! I'll keep trying.
foxyjoe is offline   Reply With Quote
