Old 05-06-2006, 10:21 PM   #1
dave666693
dave666693's Avatar
Saddle tank question
I want to take the gas tank out of the cab and use my factory installed saddle tanks. Is there a sending unit that will install in at least one of these tanks that I can wire right into the existing guage?
dave666693 is offline   Reply With Quote
Old 05-07-2006, 06:46 AM   #2
Re: Saddle tank question
Yes,doesn`t your`s already have that?There`s the driver`s side factory tank that fills with a cap in the body at the same height as the filler in the cab.The gauge is controlled by a knob that matches the rest and is located to the left of the gauge cluster.
Then,there`s the aftermarket saddle tanks that usually fill through an access door lower in the body of through the wheelwell.The gauge with those is controlled with a toggle switch.
Both types use the same type valve for controlling the tanks:factory...2-way/aftermarket...3-way.I guess both saddle tanks will give about as much as the in-cab tank.I`ve never had to replace a sending unit.If your`s don`t have them,I`m not sure where to find them other than an RV supply or truck upfitter.
Old 05-07-2006, 07:14 AM   #3
72armyswbtruck
72armyswbtruck's Avatar
Let me know how this works out, I want to do the same thing to my truck, I had to re-wire and plum my saddle tanks so they all would work,
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 05-07-2006, 08:41 AM   #4
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
I have a factory saddle tank in my 72. The sending unit is lo no longer available. If ya find a source DO post it in the FAQ's. I went with a vdo variable sending unit (fit pretty much in original hole) and plumbed in a new fuel pickup.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 05-07-2006, 10:00 AM   #5
dave666693
dave666693's Avatar
That is good info Special K. Obvious to me now that I have after market tanks but there is no switch or even sending units in them.
Old 05-07-2006, 11:48 AM   #6
qksilver
I can't remember exactly where, but in reading thru some catalogs the other day, I saw a few different adjustable sender units.
Factory part isn't avaiable but there are a lot of aftermarket choices.
qksilver is offline   Reply With Quote
Old 05-07-2006, 09:11 PM   #7
I wonder if the Coast to Coast RV catalog has them.I guess some tanks were installed w/o any provision for gauges(sending units).There must be a universal/adjustable float sending unit.Or,some people remove these tanks.Post a WTB for sending units.
Old 05-07-2006, 09:17 PM   #8
cableguy0
sounds like you have the same saddle tanks that i ripped out of my truck becuase they leaked and didnt have sending units. it looks like they torched a hole in each bed side for the filler neck. it appeared to be a dealer installed option. the saddle tanks were about 20 gallons a piece if im remembering right
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
