Old 05-08-2006, 10:22 AM   #1
hoser
Dual Tank Switch
I was thinking of setting up a dual tank setup on my truck some place I seen a universal dual tank kit and switch but dont remember where has anybody else done this, what parts did you use?
Thanks in advance.
hoser is offline   Reply With Quote
Old 05-08-2006, 10:52 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Dual Tank Switch
Auto zone carries the valves.unless you are planning on using a fuel gauge too, a plain toggle will work for the switch. If you plan on a gauge then you will need a stock switch, it diverts power plus sending unit wire.A mid 80's chevy or f@rd carbed will work.
sneakysnake is offline   Reply With Quote
Old 05-08-2006, 02:58 PM   #3
hoser
Thanks that is what I need not sure about the return lines tho, this is for my toy hauler project, I dont need a gauge I am adding a 40 gallon tank I can fill both and run the 40 gallon dry (one without gauge) then switch to the main tank with the guage.
Old 05-08-2006, 03:02 PM   #4
hoser
The tank
Old 05-08-2006, 03:04 PM   #5
hoser
3rd try
Old 05-08-2006, 03:05 PM   #6
hoser
Guess you dont get to see it
Old 05-09-2006, 12:29 AM   #7
4x4Poet
Pollak Fuel Switching Valve: EFI version
They offer a cheaper non-EFI version, too.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 05-09-2006, 11:25 AM   #8
farside847
farside847's Avatar
I got a switch from kragen years ago for another truck that switched both the fuel line and the sender wire so the guage always showed the fuel level of the
tank being used. $20 then....
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 05-09-2006, 01:36 PM   #9
badpeanut
Not a bad nut after all..
badpeanut's Avatar
I just bought a 6-port (supply and return for main and auxilliary tank) switch that looks like the one sneakysnake posted at O'Rielly for $63 (Borg Warner brand). With no power this switch defaults to the main tank. With power it switches to the auxilliary tank. My auxilliary tank has no sending unit so I'm not going here, but I think the gas gauge could be handled through a fancier dash switch (I'm using a simple on/off toggle switch).
badpeanut is offline   Reply With Quote
