05-08-2006, 02:22 PM | #1 |
Distributor Worn???
Jjust by loosening hold down 3/4 turn, timing light is very erratic - does that indicate worn shaft or gear? I have never experienced this much play before while running an engine for timing adjustment. Is this normal amount of play in chevy block when loosened?
Thanks |
05-08-2006, 06:56 PM | #2 |
Re: Distributor Worn???
Just so we understand,,, You loosen the hold down and that causes the light to freek out? That is what you're saying? I don't see how. 3/4 turn isn't even enough to allow the dizzy to ride up on the gears, or least I don't think so.
Anyway, here's a ttt for you. |
05-08-2006, 10:28 PM | #3 |
Could be, and it wont do it when it is tightened down?If it still does it then more likely the timming chain.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
05-08-2006, 11:29 PM | #4 |
Msgt USAF Ret
http://www.rustpuppy.org/ignition2/Ignition%202b.htm
Check this website on distributors. It may have the answer for you.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
05-09-2006, 12:21 AM | #5 |
Rustpuppy
great site
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
05-09-2006, 07:20 AM | #6 |
It's a quick check to pull it - there really shouldn't be any noticeable looseness in the shaft, and no more than (I think) .030 end play.
If the nut is loose enough that the distributor can move up and down then you're going to see timing chains - the gear is helical cut, so it wants to move. My $.02 |
05-09-2006, 04:48 PM | #7 |
Thanks for the advice Billla. I'll check it out. Don't have a dial caliper, but can find someone to help measure. Great website Vettevet. And yes, it is fine once tightened down, but still shifts a bit until the very last tightening up. That's what surprised me. I will check for gear and shaft bearing wear next time I can get to the truck (3 weeks).
05-09-2006, 05:36 PM | #8 | |
A feeler gauge will work just fine for end-play; it ain't an exact science |
