long or short h2o pump?
which pump do I need on my crate 350? It came with a long style pump. I am putting Vintage Air in the non a/c truck and want it to go thru the passenger side... so, the alternator should go on the driver side. I am hearing differing things and need some help... thanks
'67/70 Chevy C/10 '10 2500 Crewcab Duramax 4wd |
Re: long or short h2o pump?
forgot to mention... its gonna use a vbelt, not a serp
its all about the +6 inches
short.
#4 | |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
Going with a short pump will be easier if your crate motor has a steel timing chain cover (not plastic - i.e. Ram Jet). With the short pump you can get the ac hose kit that is allready crimped - less hassle during install - just make sure you get the proper pulleys also for belt alingment.
Semi-Senior Member
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre '83 Jeep CJ-7, <80,000 miles, original owner '04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer '95 GMC K1500 Extended cab |
Short. I went the long pump route and never could find hoses that fit right. 67-72's came with short pumps, so finding replacement parts is easier.
Cantankerous Geezer
I made the mistake of switching to a long pump. Brackets pulleys are a problem. The lower radiator hose is a whole nother issue. If I had it to do over again, I would stick with the short pump.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
