05-15-2006, 07:48 PM | #1 |
coil springs
I have a 67 1/2 ton 2wd with a 283. I want to drop the front end .I need to know how much to cut out of a coil spring for a 2 inch drop? I'm going the cheap way out.
05-15-2006, 08:01 PM | #2 |
Re: coil springs
Your're going to get several opinions on this but to me the only way the spring will fit properly is to cut exactly one coil off, no more, no less and see what you get.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
05-15-2006, 08:07 PM | #3 |
67-72 Addict!
Re: coil springs
I cut 1 1/4 coils and got about 2.75" drop.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
05-15-2006, 08:45 PM | #4 |
its all about the +6 inches
Re: coil springs
one coil should be about 2 inches, and I agree, it'll only fit properly if you do a full coil.
