leaf spring question
What i do know is the 72 blazer has a 46" front spring and 52" rear spring.
I was told the 73-up has a 50" front and a ? rear. Does anyone know the exact length of both front and rear of the next gen blazers? I'm still running stacked blocks in the rear and i want to do something different with it. so i'm looking at used springs but I'm not sure what other springs will fit the rear.
If it aint broke..............fix it till it is. www.fast77.com 1972 - 330 hp crate, 11" lift with 39x18 mickeys. 3/4 ton, cross steer, 4 wheel disc brakes 1996 Z71 w/ 35's |
Re: leaf spring question
The rear springs are 52" the same on most 69-87, but some have 56" rear springs so you will have to measure.
1972 Chevy Blazer 1997 GMC Sierra 2009 Chevy Tahoe |
#3 | |
Yes, just measure straight across from spring eye to spring eye and it should be either 52" or 56" most that i've seen are 52".
So i get a phone call for the 4" springs i'm trying to sell and the guy wants to know how long they are so i actually measure them and they are only 44", i measured on the truck and they are 44" as well, so now i'm confused, where does the 46" come in?
That was measure from bolt center to bolt center.
#6 | |
With the spring uninstalled, I think it measures 44". Once it flexes down, when installed, the rear coupler bracket that holds the spring swings back about 2 inches, I think that's when it measures 46".
#8 | |
i got 46" from the board as well as the 4wd shop...... the rear does measure 52, but i actually get 43 1/2 as well, i just rounded it up to 44.
Don`t let this confuse you.Just know what they came off of.The spring length
is all the same on all models`73-up front springs.Same with the rears 1st gen.all the way to the end of 2nd gen.and pickups.The Suburbans had longer springs in the rear.You can always pick a lift kit company`s brain,then buy used.
#11 | |
