![]() Join Date: Nov 2002
parting out 69 1 ton
got it home did a compression and test and have decided to part it out rather than fix it. Everything will not include shipping. Truck is a 6-cyl (292) auto, pb. Let me know what you want off of this. The heater controls, black arm rests and the dash pad are spoken for. I'll start with:
west coast mirrors-$10 each auto. linkage-$30 metal dust cover $10 Last edited by 67sss; 05-21-2006 at 07:14 PM. |
Re: parting out 69 1 ton
oops! wrong place,hopefully MOD can move it for me .
![]() Join Date: Jan 2002
does it have the auto crossmember?I need the spacers where it bolts to the frame.thanks
1968 Custom 10 SWB 1970 2wd Blazer 350/400 1972 K20 292/350 |
clearance lite pics
bobvilla67- yes it has the auto crossmember, not sure by what you mean about the spacers? |
its all about the +6 inches
They are faded pretty bad.. .I'll pass and let some one more desperate than me grab them.
Thanks |
I'll take the light lenses!!!!!!
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
Robert- yours PM sent
Not a bad nut after all..
I'm looking for leaf spring rear suspension exhaust hangers for the passenger's side.
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
Have a torch? I need the center section of the cross member that the driveline passes through. I only need the center section so if you could cut it on each side of where the rear trailing arms bolt up, that would be perfect. I am in no real hurry so if you wanted to wait until you sold things that made it easier to get to, that would be fine.
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
I have a crossmember from a 1/2 ton and it is to small for the 1 ton frame I have.someone posted pics from a 1 ton crossmember and it looks like a spacer on the bottom where it bolts to the frame.is the whole croosmember different from the 1 ton and 1/2 ton?I 'm not sure maybe someone can answer.thanks
Member #1049
Yes all the AT crossmembers are the same.. the 1 tons have a spacer..
Not trying to hijack your thread here but.....so I need a cross member from a 1/2 ton or 3/4 ton only?
I'll take some pics later of both x members and maybe that'll help.
Do you have a pic of the engine and air cleaner if original? Does it have PS?
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible. |
#15 |
bobvilla- here's a set of spacers for you.
badpeanut-leaf spring rearend pic and a pass. side exhaust hanger. silvertonguedevil- 2 pics of x members for you. chucks70- engine pic for you- only 1 bracket left of the air cleaner setup. I'll check with my cousin, I know he has a complete setup. No P.S. on this. I have a ps gearbox in the shop or are they diff. on a 1 ton. |
#16 |
more pics
#17 |
67sss, thanks for the pics but those cross members are totally different from what I have/need. I guess I need at least a 1/2 ton or a 3/4 ton. Thanks again.
#18 |
no problem...turn em over, I'm sure they'd work.
#19 |
Is it me, or are the mirrors different on each side?
#20 |
![]() Join Date: Sep 2002
How much for the air cleaner assembly shipped to 08753?
Thanks. |
#21 |
Attached is a picture of the exhaust hanger I need. It mounts to the crossmember ahead of the rear wheels. Probably either passenger's or driver's side would work. Does this truck have one that looks like this?
#22 |
bobvilla-$34 to your door
scottH- I have to figure the weight and I'll get back to you. 1969K10-I went and looked at the mirrors and to me they look the same, but I wear glasses! badpeanut-sorry man, went and looked and this truck doesn't have it. |
#23 |
I'm interested in the air cleaner, heat riser tube and assorted parts for the air cleaner. Also interested in the water pump pulley, alternator upper and lower bracket and alternator if any good. Could you check the manual steering box and see if it is tight or leaking.
Shipping to 26003 Thanks Chuck
#24 |
chucks-here's a few pics for you. the air cleaner assembly is at my cousins house and he wants $75 for the complete set up. Steering box is dry and seems pretty tight. If you want the alt. brackets, water pump pully and the gearbox, hows $45 plus shipping. I'll take it all off and give you exact shipping if you want it all.
Thanks. |
#25 |
From what I can see, I don't need the alt. brackets just the water pump pulley. How about $120 for air cleaner and all associated attachments/hoses, heat riser tube and carb spacer, steering gear box, pulley and both mirrors. Plus shipping to 26003.
Thanks Chuck
