05-22-2006, 12:19 AM | #1 |
Roll in bedliner question
Ok so I am wanting to do a roll in bedliner for my truck. My truck is primer now and will be for a while and I plan to paint it later. Should I do the bed liner before or after i paint it? I was wondering about masking it of what line will be there. I dont hall alot with it but I want to clean it up. What are some of the better brands to look for? Also could you guys post some pictures of yours? Thanks
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
05-22-2006, 12:47 AM | #2 |
Questionable
Re: Roll in bedliner question
don't do it. roll-in sucks. there is no reputable roll-in product on the market. go with Line-X, this is the absolute one place that you DO NOT want to skimp on your truck - roll-in liners cannot be taken out later in any easy way.
Line-x will cost you a couple hundred. it doesn't crack, peel, fade, "pore" or anything.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
05-22-2006, 06:41 AM | #3 |
Roll-on does nothing for appearance but make your bed look poopy.I have used spray-on and it looks great.I put it on my ladder racks.It`s holding up very well,but will wear off from dragging heavy stuff across the edges.More durable than any paint.Not as tough as Line-X,which is the only company I`d go with if not doing it myself.I`ve used that and I love it.All this stuff will gouge with the right edge/weight/movement in one spot.It`s not invinsible,nothing is.
05-23-2006, 12:23 AM | #4 |
A guy with a truck
Agreed. Roll-in in my old bed was JUNK. Faded, peeling, thin junk. I would almost rather suggest a good undercoating as a cheap substitute.
-Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
05-23-2006, 12:28 AM | #5 |
ives used it 4 times and all have with stood a lot of abuse. The key to them is prep work. You have to clean clean and clean some more. I have had nothing but good luck the times ive used it. Not one is peeling, cracking poored or anything yet.
1969 c10 stepside 250 inline six, 4speed granny tranny, 4.11 posi rear end |
05-23-2006, 01:12 AM | #6 |
same outcome as doug. i did the WALMART roll-in liner in my 96 Z71 and it worked fine. had lots of abuse to. (dirt bikes,etc.) the key is PREP as doug said. i sanded mine with 220, then wiped it down with paint prep cleaner/degreaser, then coated if front to back 2x. i just did the bottom of my new bed on sunday and i think it will be fine for a long time. just prep the primer and paint it.
if you can afford the LINE-X or RHINO its prob. a better deal but cost more $$$. if you worried about a line just tape it off wherever you want it to stop then paint up to that line. good luck |
