05-22-2006, 11:47 AM | #1 |
Nitrogen
Why do I need N2 in my tires? I have always put air in them before and now the sales person informs me about the error of my ways. The nitrogen will keep the tire cooler, will improve MPG, will not break down the rubber, and bring me a beer if I am watching TV. Well....... if anyone else can inform me on what else I have been missing, lets share. Steve
1969 C10 Long Step,355,700r4w/lockup, HEI,Weiand,750 Performer,1.6 rockers,Camel Humps,Comp 262Extreme,Hedman,2 1/2"pipes, tele/tilt,SunRoof,ps,Disc pb,ac,Cragar,eaton,Corvette style roll pan, Bowtie louvered tail gate,lowered 2/2. |
05-22-2006, 12:05 PM | #2 |
Keep On Truckin'
Re: Nitrogen
that's a new one on me... maybe he sells Nitrogen too...
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
05-22-2006, 12:33 PM | #3 |
'69 Step
Re: Nitrogen
how come they come from the factory with room air in them then??
05-22-2006, 01:00 PM | #4 |
GEARHEAD
Re: Nitrogen
Air=79% Nitrogen+21% oxygen
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
05-22-2006, 01:39 PM | #5 |
Re: Nitrogen
actually it would be an awefull lot better to use helium that way you'd get a feeling of floating over the potholes and your truck wouldn't weigh as much and your beer would be colder
05-22-2006, 03:31 PM | #6 |
graphic designer
Re: Nitrogen
nitrogen molecules are larger, therefore are less likely to escape and it is more stable, ie you won't get as much pressure variation when the tires heat up. if it's free, great, but don't go paying for it unless you have a race car...
05-22-2006, 03:43 PM | #7 |
Re: Nitrogen
I was going to throw in there that racers use it. It is more stable and expands and contracts less than just "air" I can't imagine a fill up with it being too awful expensive, but I have been wrong before.
05-22-2006, 06:33 PM | #8 | |
Re: Nitrogen
05-22-2006, 03:46 PM | #9 |
Re: Nitrogen
I have 2 tanks on my service truck and I have used it when I have had a flat tire (slow leak), until I get it fixed.
1997 GMC Sierra Ext 1965 Mustang |
05-22-2006, 04:10 PM | #10 |
Re: Nitrogen
We used to use it race car tires cause it won't heat up & expand like air will & mess up your stagger, but it seems kinda crazy to use for street cars.
05-22-2006, 07:01 PM | #11 |
Re: Nitrogen
We use dry nitrogen in aircraft tires...never thought much about it but maybe it won't support combustion??? It has no moisture or oxygen to cause oxydation. I guess its all about safety.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
05-22-2006, 08:02 PM | #12 |
Re: Nitrogen
For a street vehicle in my opinion...for a race car its legit.....Can you say OVERKILL
Shane
1993 K1500 350 5 speed 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ) Member#20327 |
05-22-2006, 08:48 PM | #13 | |
Re: Nitrogen
I imagine the reason it is used in aircraft tires is the extreme temp. differences experieced. On the ground the ambient temps would vary greatly compared 10,000'+. This might create a massive pressure swing with air, especially if the tires were inflated in an extremely humid climate then climbed to 30,000', then rapidly descended to sea level. It would probably be like landing on Marshmallows. Nitrogen is dry, and yes inert, and not as suceptable(sp?) to temp changes. Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! |
