05-22-2006, 01:56 PM | #1 |
Went to track last friday
Turned out to be a good test day overall. Truck went 11.45@118 on its first day with my homemade twin turbo blowthrough carb setup at 8 psi. This is actually very good considering that its sucking in underhood air which is too hot to begin with and then not even having an intercooler. I'll get the piping built to go through the radiator support and a roll bar so I'm legal again before I go back. 60ft was only 1.69 which is kinda lazy so hopefully its got a few tenths left in it. Here's a couple pics of the new setup.
85 GMC 1/2 ton LWB 4150lbs. 383 SBC with Twin MPT70 Turbos 850 CSU carb TH375 3.70 gears Ultimate 10" Converter 10.11@136.6 with 1.64 60ft. on 10.5-31-15W |
05-22-2006, 02:42 PM | #2 |
yeller
Re: Went to track last friday
That is pretty sweet, good times too!
Do you have any more pics of your truck? What else have you done to your drivetrain (rear, trans, etc) to allow it to handle that kind of power?
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
05-22-2006, 03:25 PM | #3 |
Wow! That looks really sweet!! I bet that BOV sounds pretty sweet from the front, forward facing like that.
05-22-2006, 05:06 PM | #4 |
paper or plastic?
Neat
1967 Chevy SWB 250 http://67-72chevytrucks.com/vboard/s...d.php?t=442157 1977 Chevy SWB 454 No More 454 getting 5.3 http://67-72chevytrucks.com/vboard/s...d.php?t=310518 1977 Stepside Truck of the month winner http://67-72chevytrucks.com/vboard/s...d.php?t=135524 1965 Chevy C10 454 http://67-72chevytrucks.com/vboard/s...d.php?t=731372 1975 Dodge Power Wagon http://67-72chevytrucks.com/vboard/s...=1#post7871388 |
05-23-2006, 11:12 AM | #5 | |
There isn't anything too fancy on this thing. I run a turbo 350 with good clutches and hardened sprag race. The rear is a 9 inch from a pickup narrowed to fit with moser axles and a spool. Modified caltracs bars help plant the tires. I even use the trusty old two peice driveshaft. Here's a pic from Brainerd last year on top. This was a 12.29 run. Bottom is from friday's 11.51 run.
85 GMC 1/2 ton LWB 4150lbs. 383 SBC with Twin MPT70 Turbos 850 CSU carb TH375 3.70 gears Ultimate 10" Converter 10.11@136.6 with 1.64 60ft. on 10.5-31-15W Last edited by BADGMC; 05-23-2006 at 02:44 PM. Reason: Found another pic. |
05-24-2006, 06:51 PM | #6 |
Sweet , here is a pic of my Suburban !! I have been considering selling it but NMCA will be here in July !!
1987 Suburban , 406 , 400 trans , Dana 60 Rearend ,4.10 gears. Chevy tough |
05-24-2006, 07:36 PM | #7 |
Hotwheels?
Holy shi... 11.4 in a LWB. I see you had CSU build you a nice carb there.
You over at turbomustangs.com too?
1978 Money Pit - CUSTOM DELUXE!!!! |
05-24-2006, 08:24 PM | #8 |
No No
Thats bad! Especially in a LWB
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
05-24-2006, 09:03 PM | #9 |
I see you went with the dual turbo. I was gonna go with a single, and have a crossover pipe in front, like over at www.toohighpsi.com. But I jsut want a bit more response at highway speeds.
I figure I'll just fab up what I need. Just need to select the turbo, wastegate assembly, plumb oil lines... Aahh, jeez. Well, Winter'll be here in 6 months... I've been wanting to go turbo for a long time. My '77 will like it. |
05-25-2006, 09:05 AM | #10 | |
Insert Witty Text Here
Slonaker |
05-24-2006, 09:46 PM | #11 |
yeller
That is sweet, very good times from a stock appearing truck. I hope to dip into the 12's with my truck once it is finished...and that's with a mostly stock 454. What you are doing with a small block in a heavier truck (mine is a swb) is simply sweet! It would be cool to meet up with you someday, I am out of the twin cities area.
By the way, I thought BIR was called Cornels (sp?) or whatever, I thought the title BIR went away?
05-24-2006, 11:01 PM | #12 |
Were did you get thoes hydroboost lines?
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
05-25-2006, 12:50 AM | #13 |
The hydroboost lines are just Aeroquip TFE lines, they came with the booster kit from hydratech. Also anyone around up here should come to the Show and Go for a day or something on the july 4th weekend as there is usually a bunch of our trucks there and its a lot of fun. I am trying my best to be one of the faster ones but its quite a battle.
05-25-2006, 06:56 AM | #14 |
yeller
The Show and Go is a fun event, especially if you camp out for the weekend at the track!! I did it one year a few years back, had a blast.
05-26-2006, 09:06 PM | #15 |
I'll be using CSU for my carb also, GREAT times!
~Steve~
Friesen High Performance Auto and Graphics Toy: 87 Shortwide, 406 smallblock with a little boost My 87 buildup Daily Driver: 99 Sierra SLE 4X4. Black on Black and harder than hell to keep clean. Last edited by 1987 Shortwide; 05-26-2006 at 09:06 PM. |
05-26-2006, 09:26 PM | #16 |
The best part of CSU is the service that they provide. Anytime you have a problem call them and they will take time to help out. You won't get that from a big outfit.
05-26-2006, 09:59 PM | #17 |
I agree... I emailed the owner reguarding my single turbo truck setup and my dad's twin turbo big block setup and the next day he called me out of the blue. you WILL NEVER recieve that kind of service from a large chain. He wasted 30 minutes of his day on the phone with me and I never even hinted that I was going with his carbs.
~Steve~
Friesen High Performance Auto and Graphics Toy: 87 Shortwide, 406 smallblock with a little boost My 87 buildup Daily Driver: 99 Sierra SLE 4X4. Black on Black and harder than hell to keep clean. |
