Old 05-30-2006, 09:51 AM   #1
67ChevyRedneck
67ChevyRedneck's Avatar
What do these frame numbers mean?
Found this on my frame when I took me bed off. It says: CS10704 The C looks like an "E" but I think it's supposed to be a "C". It doesn't match my vin and it doesn't appear to be a date.... anyone know what these numbers are? They might not mean anything, but I thought it was cool to find the original chalk numbers on my frame.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 05-30-2006, 10:02 AM   #2
shifty
Questionable
shifty's Avatar
Re: What do these frame numbers mean?
EDIT: ok, it's the model, not a partial VIN, i'm an idiot.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 05-30-2006, 10:04 AM   #3
shifty
Questionable
shifty's Avatar
PS - some members find these inside their engine bay area on the firewall/cowl area. it's something they sketch on at the factory on the assembly line with wax marker.
if you want to verify your frame is actually for your truck, there are several places to find a partial VIN. Here's a thread to ID those: http://67-72chevytrucks.com/vboard/s...hlight=partial
Old 05-30-2006, 10:14 AM   #4
67ChevyRedneck
Interesting, I've seen trucks with the numbers on the cowl before.
So if I've got this right... the CS is a 6cyl 4x2 (which the truck WAS) 1 = 1/2 ton, 07 = Cab To Axle Dimension 07 = 42"-47", and the 04 = 04 = Stepside Pickup
Cool. I'm sure the frame is original. The truck was unmolested when I bought it (original paint) and the frame didn't have the dimple in it.
Jesse James
Project "On a Dime"
Old 05-30-2006, 11:26 AM   #5
shifty
Questionable
shifty's Avatar
i am sorry. i was wrong. that information you have is the model for your truck and basically is the option description. look at this: http://satellitehead.com/images/68ch...0_SB%20001.jpg
i have the same truck as yours, probably same options, except mine is a 68. didn't mean to mislead you.
i suppose they sketched this onto the frames when rolling through the line to make sure the right cab goes on the right chassis or whatever.
Old 05-30-2006, 11:37 AM   #6
67ChevyRedneck
Your truck has 4 more options than mine (and yes, I do mean to say my truck had absolutey ZERO options from the factory, NOTHING)
Jesse James
Project "On a Dime"
Old 05-30-2006, 01:22 PM   #7
shifty
Questionable
shifty's Avatar
don't let it fool you - seriously, the only option I have is heavy duty rear springs, which may or may not have been a "real" option at all. i suspect vinyl trim, the paint and painted bumper are just ... well ... something to pad the spec sheet with.
Old 05-31-2006, 02:36 AM   #8
Americanrider
It's a cryptic message from "The Creators"
I found mine on the inside of the front bumper.
Americanrider is offline   Reply With Quote
Old 05-31-2006, 10:29 AM   #9
67ChevyRedneck
What does it say on the bumper? st... grind only?
Jesse James
Project "On a Dime"
Old 05-31-2006, 10:37 AM   #10
67ChevyRedneck
Shifty, this is my glovebox sticker, and according to longhornman the deluxe heater wasn't actually an option and neither was the blue vinyle trim???
Jesse James
Project "On a Dime"
Old 05-31-2006, 01:16 PM   #11
Americanrider
I have deluxe heater list as an option on my 67, both on the build sheet & the glove box door.
I also have blue vinyl trim listed on my 70 GMC glove box.
I'm not real sure what the 1st word is in that message... maybe STRAIGHT?
Old 05-31-2006, 02:38 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have found out some info on the heater deal. I have some dealer papers from a GMC dealer in NY, and one dated towards the end of 67 states;
Even though the heater has been standard for over a yewar, you have been instructed to specify it as an option. If not specified, a heater delete will go onto that truck, and a creadit will be issueed to the buyer.
So it was basicly an option that was standard.
The blue vinal, it turns out, actually IS an option. If there was noithing listed there, then it would go to the defult int color of fawn if memory serves.
Old 05-31-2006, 03:00 PM   #13
67ChevyRedneck
Changing your tune now?
"It is odd that the heater is listed, and I'm going to guess you have an early truck, like 12 of 66 or something. (I didn't look at the sequence on your VIN)
The heater was optional before the 67 model, and in the 67 books, it shows an option for heat, but it has a line drawn through it and standard written under it.
The option for paint and int colors were to show what color it was going to be. I do think there was a 'base color' , but I have never thought of a single solid color as an option personally. (It's not even listed in options on the books)
So in all reality, you have a 0 option truck there."
~Longhornman 01-04-2006
Check out this thread, post number 12!
http://67-72chevytrucks.com/vboard/s...optioned+truck
Just messin with ya man
Jesse James
Project "On a Dime"
Old 05-31-2006, 07:06 PM   #14
larry may
Smile Re: What do these frame numbers mean?
I've been parting out a step side. Has that same number same place as you show your number. Did you install the fuel tank under the bed? What is that tank from ?
larry may is offline   Reply With Quote
Old 05-31-2006, 07:16 PM   #15
Longhorn Man
well, it was in fact speculation... now I have proof that says it was in fact standard, but left out if not requested.
Old 06-01-2006, 08:12 AM   #16
67ChevyRedneck
Larry may: The tank is a reproduction tank I got off a board member that he had bought from Christian Classics. It's a 69-72 Blazer tank. Check out this thread (it has lots of pics)
http://67-72chevytrucks.com/vboard/s...d.php?t=197895
Jesse James
Project "On a Dime"
