Old 05-31-2006, 07:45 PM   #1
DREW67
DREW67's Avatar
Cab Supports
I know this has been asked before, but what is the best way to replace a front cab support do you have to take the cab off the frame? or can you leave it on an jack it up? Do you have to un-bolt the front clip?
Thanks,
DREW67
DREW67
DREW67 is offline   Reply With Quote
Old 05-31-2006, 07:49 PM   #2
cdowns
cdowns's Avatar
Re: Cab Supports
do you mean the rubber mounting cushions ot the actual support thats welded to the frame?
Old 05-31-2006, 07:52 PM   #3
DREW67
DREW67's Avatar
Re: Cab Supports
The actual cab support that bolts to the frame.
DREW67
Old 05-31-2006, 08:31 PM   #4
Aarons72s
Re: Cab Supports
No you can leave the cab on if you are talking about the u shaped bracket rivited to the frame. I had to do that on my orange and white in 2000 when it was still active. I used a floor jack to support the cab while doing the swap. I hope this helps.
Aarons72s is offline   Reply With Quote
Old 05-31-2006, 08:47 PM   #5
DREW67
DREW67's Avatar
Re: Cab Supports
NONONO! I mean the cab supports that are welded to the cab there are four of them two in the front to in the back.
DREW67
Old 05-31-2006, 09:01 PM   #6
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Cab Supports
You mean the one of these in the pic, or the steel brackets that are rivited to the frame?
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 05-31-2006, 09:21 PM   #7
DREW67
DREW67's Avatar
Re: Cab Supports
Yeah the middle one.
DREW67
Old 05-31-2006, 09:28 PM   #8
glock35ipsc
Re: Cab Supports
I have not done one myself yet, but I think you can leave the cab as-is.
Bob
Old 05-31-2006, 09:42 PM   #9
ebfabman
Re: Cab Supports
You will have to remove the hood then unbolt the fenders and the take out the cab support bolts on the side you will be replacing the cab supports on. Don't have to remove the cab just jack up the side you're working on.
ebfabman is offline   Reply With Quote
