Old 06-04-2006, 11:01 PM   #1
72MARIO
72MARIO's Avatar
Air Bags for rear of 3/4 ton ?
Hi I am looking at buying a 3/4ton with trailing arm suspension and want to use it to work with. I will be hauling 4000 pounds at times along with towing a trailer. I would like to know if there are air bags that would hold up to that kind od load as well as give me stck ride height. I dont want it to be sitting really low when loaded.
Thanks for the help,
Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-08-2011, 12:29 AM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Air Bags for rear of 3/4 ton ?
I'm searching the forums for that exact question.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 02-08-2011, 12:54 AM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
Look at the Slam Specialties HE or XE series in a 7 or 8" diameter. You will want to use mounting cups to take up the space between installed height of the bag and stock springs.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-08-2011, 08:05 PM   #4
72MARIO
72MARIO's Avatar
Wow this is like digging up a gave.
Glad you got a answer I ended up leaf sprung and air over leaf setup.
2005 TAHOE DD
Old 02-08-2011, 08:08 PM   #5
LostMy65
LostMy65's Avatar
I don't think it's necessary to start a new thread - we just end up with multiple threads on the same subject, with partial answers fragmented all over the forums.
Old 02-09-2011, 12:22 AM   #6
dubds10
Stalker Nate
4-link with bags over axle if you plan on carrying any large amount of weight. Any larger bags should do the trick although look at the specs of them before buying of course. If the bags aren't over axle you will lose towing capacity the further they are placed away from the axle.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
