Old 06-05-2006, 08:03 PM   #1
62 short step
62 short step's Avatar
power steering 61 4x4
Does someone know what year power steering box will work on a 61 chevy 4x4. Jeremy
62 short step is offline   Reply With Quote
Old 06-14-2006, 01:42 AM   #2
BrianJordan
Iron Thunder
BrianJordan's Avatar
Re: power steering 61 4x4
67-72 sould work, you mite need to pull a hole to make it fit.
BrianJordan is offline   Reply With Quote
Old 06-14-2006, 09:36 PM   #3
62 short step
I guess the rez steering box bracket will be needed? Jeremy
Old 06-15-2006, 06:27 PM   #4
Vaughn
Depends on whether it is a 3/4 ton or 1/2 ton. The 3/4 ton frame is 7 inches wide just behind the cab, the 1/2 ton frame is 6 inches wide just behind the cab. The shorter frame will require the Rez Adpater or something similar, the taller frame does not require an adapter.
Vaughn is offline   Reply With Quote
Old 06-15-2006, 11:16 PM   #5
62 short step
It's a 1/2 ton so I guess I'll have to get an adapter. Jeremy
Old 06-25-2006, 08:49 AM   #6
624whldr
drive it not trailer it
did you get the ps on your 62 as im looking to do it also but i question the 69-72 boxes as they swing differently that could cause the axle steering arm to hit the spring plates please let me know as mine is now being reassembled thanks, ed
624whldr is offline   Reply With Quote
Old 06-25-2006, 09:17 AM   #7
62 short step
I have not done mine yet, trying to get my plans straight to determine what I'm going to do. Jeremy
