Old 08-02-2002, 10:40 AM   #1
Jefe
Jefe's Avatar
400 heads on a 350?...
Can you put 400 heads on a 350? Other than the steam holes in the 400 heads they should fit right??
Thanks.
Jefe is offline   Reply With Quote
Old 08-02-2002, 11:20 AM   #2
Model 12
I think so...but they are probably worth more to a 400 SB owner than to you as a modified engine guy. They are rare as they were bad to crack (so I've heard).
If James Dean had a truck, it would be a Cheyenne Super...
Model 12 is offline   Reply With Quote
Old 08-02-2002, 11:56 AM   #3
diggin69
Southern but in Ohio!!!!
diggin69's Avatar
most parts from 265-400 will interchange if you can swing it I like to go with 64cc heads little more cumbustion, & compression.
1969 C/10 3/4 ton 4x4 longbed custom, frame made from a 79
1972 custom-10 half/ton longbed
1980 1/2 ton 4x4 all original 350/350/205 with air
Eaton,Oh
rebelryder@hotmail.com
diggin69 is offline   Reply With Quote
Old 08-02-2002, 06:04 PM   #4
67 SS
I'd have to agree with Model 12.Sell them to a 400 owner and buy some good performance heads.
67 SS is offline   Reply With Quote
Old 08-04-2002, 11:29 AM   #5
MikeB
MikeB's Avatar
Have them magnafluxed before you spend a nickle on them, and don't use them because you think they are bigger or better than 350 heads. Chevy did NOT make a performance version of the 400. It was built to make gobs of torque from idle to 2500 rpm and peak horspepower (not much) at maybe 3500 rpm. Also, the combustion chambers are 76cc, so you'd need flat-top pistons with a 350 to get 9:1 compression.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 08-04-2002, 11:45 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Plus, they are probabbly 882 heads, which aren't woth jack.
Old 08-04-2002, 01:59 PM   #7
Jefe
Jefe's Avatar
well.
Here's the deal...I am building a 400...bored .60 over 292 Comp Magnum Cam, Keith Black Pistons etc etc. Well if the motor doesn't come out the way I want it...I was wondering if I could use the heads on another small block...they are already set up 2.02/1.60 Manley Stainless Valves, RV springs, new guides/keepers all the works. So they are done..just wanted to know if they can be used on anything else.
