eaton third w/load bolt
if an eaton third member has a load bolt, does that mean it has a locker in it, or is it just that MOST lockers came with load bolts?
1969 SS 350 Camaro Sold 2008 1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's ![]() 1980 Chevy Malibu 2 dr Sold 2007 1993 Olds. Cutlass Ciera Wagon Traded 2006 2003 Saturn L200 w/5pd. D/D My list spans 5 decades with One common thread.....GM! |
its all about the +6 inches
Re: eaton third w/load bolt
every eaton I have seen had the load bolt.
I have to disagree Andy. There is no load bolt my 67K-20 w/HO-52. I just went out and checked to be sure. Load bolts do not indicate a locker, it is just an adjustment tool for setting the pinion load.
GM just used what came along on the assembly line I guess. My truck has the HO52 rear with the load bolt, and so does the Suburban I just got. My truck has a locker, not sure about the Suburban though.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
The "Load" bolt is to push a bronze plug against the back of the ring gear carrier to , in a manner, keep the gears better in mesh under load. it actualy is set with a slight clearance on proper set up and has nothing at all to do with "setting" the gear mesh. Under load the gears want to open up and this "Load" bolt prevents that.
