Old 06-09-2006, 12:26 AM   #1
cornutz
All Praise RANDY!!
cornutz's Avatar
HELP!!! PART 2... Manual Prop valve
I was told by Stan at ECE to set up the stock master cylinder with an adjustable one like the one in the link below to the rear brakes... you see I am adding rear disc to the burb... my question is how the hell do hook this bad boy up? the lines seem to be of different size... at least, I think the rear line is the beefier 1/4 inch line out of the stock master cylinder... so are there fittings to adapt this thing??
http://www.wilwood.com/Products/006-...1-PV/index.asp
Thanks,
cornutz is offline   Reply With Quote
Old 06-09-2006, 01:21 AM   #2
Oldtruckfanatic
Truck junkie
Oldtruckfanatic's Avatar
Re: HELP!!! PART 2... Manual Prop valve
The threads on those valves are just 1/8 inch pipe. You can buy fittings to adapt from the 3/16 female inverted flare that that the valve comes with...You need an adaptor thats 3/16 male inverted flare to 1/4 female inverted flare or 1/8 male pipe to 1/4 female inverted flare. most auto parts places have the fittings but sometimes the guys at the counter don't know what they are.
Oldtruckfanatic is offline   Reply With Quote
Old 06-09-2006, 01:27 AM   #3
cornutz
All Praise RANDY!!
cornutz's Avatar
Thanks!!! I REALLY appreciate your help!!!
