Big Block 396
I have a 396 bored 60 over COMPLETE all you need to do is drop it in and fire it up. cloys gear drive, edelbrock aluminum roller rockers, air gap intake,750 Edelbrock carb,Crane Energizer 103052 2000-5000 RPM 272/272 Advertise Duration, 216/216 @ .050 Duration, .515/.515 Lift, 110 Lobe Center,March aluminum pulleys, 7 quart oil pan, accel distributor and super coil, Clevite bearings, Molly rings, High volume oil pump with steele sleeve, Felpro gaskets, One piece oil pan gasket. K&N air filter top and bottum, aluminum water pump ,This Motor has less then 500 miles on it, Im asking 2500 for it. Thanks for looking
Re: Big Block 396
ttt
Can't wait to retire!!
Re: Big Block 396
ttt
Re: Big Block 396
not that I have the money, but what kinda of heads are on it?
2006 Titan SE Crew Cab Daily Driver 2005 Mazda Tribute (Wifes car) 1969 C10 SWB 350/3 Fleet "Max" 1969 Chevelle 2 door 350/3 |
Re: Big Block 396
If I still lived in Cedar Rapids I'd be there tomorrow ! ! !
Re: Big Block 396
Stock Chevy Heads Just redone for unleaded gas and 5 angle valve job id have to dig up paper work for size of valves
