Old 06-22-2006, 04:10 PM   #1
jimmmie '79 Cheyenne
hummer wheels on '79
I know the bolt pattern is the same for all 8 lugs (8 on 6.5) , but '88 to '04 and maybe current takes a 14X1.50 lug nut vs the 9/16 on pre '88. Will my lug nuts seat correctly on the newer wheels or do I need to do s o m e t h i n g .... Went out when I bought the truck and put 8 X 16.5's on it, not knowing at the time 16" was really better. Dummy me, but that was long ago in the last millinium, Jan of '79. Any idea what take-offs are going for on the newer trucks? thanks...jim
jimmmie '79 Cheyenne is offline   Reply With Quote
Old 06-22-2006, 06:14 PM   #2
kevinr1970
Re: hummer wheels on '79
If I understand what you are asking correctly, I've seen the new GM eight lug aluminum rims on Craigslist for anywhere from $250 for a set of 4 to $1200 for a set of 4 with new tires and caps/lugnuts. And everywhere in between.
The ones for $1200 seemed overpriced as there was a set of 4 with caps and lugnuts with a claimed 70% tread for $450 at the same time.
If I had a 3/4 or 1 ton, I would pick up a set.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 06-25-2006, 07:33 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I've seen Hummer wheels on a 86 Suburban!! They look sharp. You can machine the center out just a little to fit older center caps too.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
