Old 08-04-2002, 06:36 PM   #1
bigjimzlll
bigjimzlll's Avatar
scarry moment
took the new motor out for a 1/4 mile pass( its all broke in) Ran great, went through the traps(painted finish line) with the speed-o pegged..then smoke..tons of it..I cranked on the breaks and shut it down...one of the tranny coolant lines layed on the header, and pumped quarts of tranny fluid all over my new clean engine ..all i had for tools was a pocket knife ...I had an old spark plug to plug one line and i found a 1/2 inch bolt for the other..and used a dime as a screwdriver...lol..made it home safe and sound
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 08-04-2002, 08:43 PM   #2
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Wow a DIME!!!!
Keep tools all the time....that's almost written in the scriptures!!!!!
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 08-04-2002, 09:34 PM   #3
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
**** that is scary! glad you got it home though
68SWB4x4 is offline   Reply With Quote
Old 08-05-2002, 12:04 AM   #4
low 84
low 84's Avatar
did you get far enough down the track to get any times like 60 ft.?
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 08-05-2002, 12:16 AM   #5
bigjimzlll
bigjimzlll's Avatar
its migshift strip at a friends farm...just for match races and tuning and stuff,,no electronics...i had the 100mph speedo pegged and then some at the end of the 1/4..it felt like a 14 second pass, maybe a hair quicker... 0-60mph with a stop watch is 4.8 seconds.. iwas at 5300 at the end of the 1/4
Anderson,CA
Old 08-05-2002, 06:53 PM   #6
Blue68
Blue68's Avatar
Fire extinguisher anyone?
I pull mine out of the house into the garage for ALL first time events with the engine. You never know about the line, pump, gasket, etc.
So far I've only needed one when I didn't have it. Go figure. Left the oil filler cap off a overhead cam engine. I was actually able to blow the fire out....about 5 times. Wrecked the vacuum lines though.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
