06-27-2006, 09:27 AM | #1 |
new to board, need some help with 4 spd tranny swap
Hello everyone. I'm new to the board and need a bit of help. I recently bought a 4 speed saginaw to install in my 69 C-10 which originally had three on the tree. Can anyone give me detailed swap instructions (parts required, etc)? Also putting in power front disk brakes and power steering if anyone can help there as well. THANKS!
06-28-2006, 11:51 PM | #2 |
Re: new to board, need some help with 4 spd tranny swap
Can't help on the steering and brakes, but as far as the transmission:
You will obviously need to take out the 3 spd shifter linkage that goes from the steering column to the tranny. You'll keep the pedal, the rod that goes from the pedal through the firewall to the z-bar, the z-bar and bracket that attaches the z-bar to the block, and the clutch adjustment rod. New parts needed (besides transmission of course): Shifter Shifter linkage (3 rods total) As far as the bellhousing, I think that the saginaw will bolt up to the 3 spd bellhousing, but hopefully someone else can confirm that. For the procedure, I'm gonna go ahead and assume that you have the original truck bellhousing. Procedure:
I think that is most everything, but I'm tired of typing now, so I'm headed to bed. Hope this helps and good luck! |
06-28-2006, 11:52 PM | #3 |
Also welcome to the board Scott !
06-29-2006, 03:07 AM | #4 |
You running 8 or 6 in your 69? It makes a difference when you talk power steering mounts & pulleys. I6 stuff is hard to come by. Small blocks are easy to find, just be sure to line up the belts & pulleys. For Power brakes you will need: Brake booster & firewall mount Brake booster to pedal rod Master cylinder that matches the booster [both Delco-Morraine or both Bendix, they do not intechange w/ each other] New Front steel brake lines (smaller than drum lines) Disk/drum brake propotioning block What are your plans, stick with 6 lug or go to 5 lug fronts? |
06-29-2006, 09:10 AM | #5 | |
06-29-2006, 01:33 PM | #6 |
bellhousing's the same
[QUOTE=OleBlue69] As far as the bellhousing, I think that the saginaw will bolt up to the 3 spd bellhousing, but hopefully someone else can confirm that.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
06-29-2006, 09:05 AM | #7 |
American Rider, Running a 350 V8, so the pulley and bracket should be pretty easy to find, right? Off any GM V8?
06-29-2006, 11:48 AM | #8 |
Your looking for a "SHORT NECK" SBC setup. Water pumps come as short or long neck styles. Read this:
http://67-72chevytrucks.com/vboard/s...hlight=pulleys |
06-29-2006, 01:46 PM | #9 |
i just did this swap a couple months ago and love. the 4 spd case in same size the 3 spds so you should not have to change your drive shaft. all you gotta do is reomve and get rid of all the 3spd shift linkage,unbolt the tranny at the bellhousing, take it out, and bolt the new on up, cut a hole in the floor for the shifter stick, install the shifter and your set. hurst makes a real good shifter for puttin the 4 spd sag's in truck. i have it in mine. despite what peopl will tell you, sags can take some abuse and hold up good. chris.
jegs part number hurst shifter: 530-391-0001 intstall kit: 530-373-7919
07-05-2006, 01:32 PM | #10 | |
07-05-2006, 04:57 PM | #11 | |
