Old 06-29-2006, 07:17 PM   #1
ChevyDude
Start up help Please!
Ok, Trans lines arrived and are now installed. Everything is wired and hooked up...I think??? Dumped a drop or two of fuel in the carb, I turn the key...she turns over and eventully starts to cough and spurter...but won't start. I have about 6 lbs fuel pressure going into the carb. Any idea's???
Help please.
Alex
ChevyDude is offline   Reply With Quote
Old 06-29-2006, 07:29 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Start up help Please!
Not to be a smart ass, but did you pump the throttle? a couple dribbles won't do much to fire for the first time.
Old 06-29-2006, 09:02 PM   #3
ChevyDude
Yea Andy pumped the throttle kept turning key, coughing and a small fire in the carb. Not a big blasting fire like you have when you are 180 off on the dist. though.
Old 06-30-2006, 09:22 AM   #4
motocrosschump
try turning the dizzy a bit, maybe you are too far out of time. Also recheck wires. See if its dumping fuel in carb.
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 06-30-2006, 09:47 AM   #5
kingsolver72
10/30/19
kingsolver72's Avatar
What is the gap set on the spark plugs?
Fight the good fight, finish the race, keep the faith
kingsolver72 is offline   Reply With Quote
Old 06-30-2006, 10:10 AM   #6
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Just the first things that come to my mind:
* Adjust timing up a little (advance it),
* dizzy may be one tooth off,
* check spark plug wires for firing order (1-8-4-3-6-5-7-2 clockwise),
* look in the carb and work the throttle to be sure the accelerator pump is shooting fuel (not while trying to shart thought),
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 06-30-2006, 10:41 AM   #7
rodstored-72
chevy truck fan
rodstored-72's Avatar
i agree w/ motocrosshump,
when i tried to fire mine for the first time i was off on the dist. by 1 cylinder. so i moved the wires over by one & she fired right up....
good luck!!!
rodstored-72
rodstored-72 is offline   Reply With Quote
Old 06-30-2006, 11:39 AM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
About the only thing that will cause a fire in the carb is if the engine fires back through an open intake valve. This is usually caused by timing advanced too far or a sticky valve or adjusted too tight. The other possibility is the valve timing is off. If the cam and crank sprockets are misaligned then ignition timing will never be right. Your best bet is to line up the crank balancer with the timing mark with no.1 on top dead center and then set the dizzy rotor to the no.1 plug and follow the firing order as given. Be sure to go clockwise around the cap.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 06-30-2006, 11:59 AM   #9
ChevyDude
VetteVet....that makes perfect sense...will do that. I'm thinking that is the problem cause I did have the dist out for rebuilding and put it back in without worrying or thinking about the rotor position.
Thanks everyone, let me see what I get this time.
Old 06-30-2006, 02:03 PM   #10
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Just in case you didn't know , the balancer mark will come up to the timing tab twice on each crankshaft rotation. No 1 top dead center and on no.6 top dead center. That's why it needs to be on top dead center on the compression stroke for no. 1 or it will be 180 degrees off and will not start. You could still drop the distributor on no 6. and it would start as long as the no. 6 cylinder is on the compression stroke. It's amazing how simple all this is but it's the most confusing thing about an engine for most people. I know I've had my share of trouble in the early days understanding it.
VetteVet
Old 06-30-2006, 02:31 PM   #11
ChevyDude
Dude,,,Vette Vet,,,Dude....Dude,,,Dude!!!!! With 110% respect DUDE!!!!! That was it!!! Lil' Red fired right up.....un corked but breathing FIRE and freakin loud!!! Holy Crap...This is a Monumental day for me and this truck...3 years later maybe 3.5 since I pulled the engine and a lotta help from you guys and this old tile setter gets the engine running.
I am thrilled! now just the fine tuning and dialing in! Thank you so so much everyone that has helped! If you think your $25 dollars for a subscription is not worth it...think again, how much would it have cost to have a mobile mechanic come out to fire up Lil' Red??? A lot more than 25 bucks!!!
Peace out!!! Now I might start drinking again!!! Naw.
Alex
Old 06-30-2006, 05:52 PM   #12
VetteVet
Msgt USAF Ret
VetteVet's Avatar
You're welcome you just made my day.VV
VetteVet
Old 06-30-2006, 06:42 PM   #13
ChevyDude
COOL!!!
