07-01-2006, 11:50 PM | #1 |
Who's got a picture and hole size...
for where the tach factory wiring came through the firewall? I know how it all wires in the cab and have a factory tach harness...just need to drill correct size hole in the correct location.
Thanks! |
07-02-2006, 06:36 AM | #2 |
Re: Who's got a picture and hole size...
Here is a picture of the factory hole location on a 72 Suburban firewall. The hole for the grommet on the tach wire is 3/4" and is located between the bulkhead connector and the E-brake cable hole. There are "dimples" in the firewall for the location of the hole(s) to be drilled.
Jim |
07-02-2006, 10:49 AM | #3 |
Thank you very much Jim! Perfect pic of what I needed! Guess I need a 3/4" hole bit....Home Depot here I come!
Anyone adding a tach to a non tach truck....save this pic!!! Alex Last edited by ChevyDude; 07-02-2006 at 11:32 AM. |
07-02-2006, 11:00 AM | #4 |
Junior Member
I recently purchased a painless wirin harness for my 84 C20 and also want to change out my warning lights to actual gauges and add a Tach. are there any good diagrams for that and where can i get the sending units a well?
07-03-2006, 09:17 AM | #5 |
Never enough time!!
In a 67 cab that hole is 1'' diameter...or at least mine is and it doesn't look like it has been drilled out.
07-03-2006, 09:41 PM | #6 |
The factory punched the holes as can be seen on the picture of the Burb firewall. I was not sure of the year that ChevyDude has so I made sure he knew that it was a 72. I did not have a 67 to take a picture of, so if yours is different, maybe you should post a picture of it as some of these details were changed over the years.
Jim |
07-03-2006, 10:51 PM | #7 |
The tach wiring is,, one wire to the tach side of distributor cap?? Corrct me if I'm wrong. The end that plugs into the dizzy would fit through a .. 3/8" hole? 1/2" at the most? Why make a hole bigger than necessary? As long as you have a grommet to fit, I think I'd make the hole as small as possible. JMO
07-04-2006, 02:17 AM | #8 |
Mine is a 71' and a 71' factory tach harness from M&H has a 3/4" grommet.
07-04-2006, 07:49 AM | #9 |
Never enough time!!
My truck is at the body shop right now...I'll get a picture of it next time I get a chance. In my LMC book 67 is a different part number for the tach wiring harness than 68-72, possibly just because of the grommet size?
