Old 07-04-2006, 11:28 AM   #1
northerngmc
northerngmc's Avatar
6 Bolt wheels
Will these newer style Silverado 6 bolt wheels fit on my 69 GMC 1/2 ton?
Tires are BF GOODRICH RADIAL LONGTRACK T/A 245/75R/16
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 07-04-2006, 11:45 AM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: 6 Bolt wheels
If I remember correctly, the center bore is too small.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-04-2006, 01:47 PM   #3
northerngmc
Re: 6 Bolt wheels
If it helps any there are off of a 2001 Silverado.
Blaine
Old 07-04-2006, 01:56 PM   #4
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
Re: 6 Bolt wheels
i have heard the same thing, the center bore is too small, and i believe the ofset is not correct
tommie is offline   Reply With Quote
Old 07-04-2006, 02:38 PM   #5
vtblazer
vtblazer's Avatar
Re: 6 Bolt wheels
Lots of off set in those newer wheels, something like 5".
I've heard of guys having the centers machined out to fit.
vtblazer is offline   Reply With Quote
Old 07-04-2006, 03:01 PM   #6
northerngmc
Re: 6 Bolt wheels
Not looking for a lot of work, just a deal on a set of wheels and tires.
Blaine
Old 07-04-2006, 03:42 PM   #7
glock35ipsc
Re: 6 Bolt wheels
I tried the use the ones off of my 2003 Silverado on my 68, and thats when I found the center bore to be too small. The bolt pattern is metric (I think), but will work. Might be worth a call to a couple of machine shops to see what it would cost to chuck them up in a lathe and open them up a bit. Would be really easy if you could find a lathe with a big enough swing.
Bob
Old 07-04-2006, 03:56 PM   #8
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: 6 Bolt wheels
All replies about the center bore being too small are correct. I ran into the same problem with the wheels I'm currently running. I chose to pull the axles and have the flanges machined down to correct it. Up front I was fine since I have a late-model disc conversion. I am running 1-1/2" spacers out back to correct the backspacing issue. Up front, no spacers as the drop spindles and disc conversion already gave me a wider track width than stock so it was fine.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 07-05-2006, 09:50 AM   #9
motocrosschump
Re: 6 Bolt wheels
Center is too small. Had the exact same wheels. This is what I found. Offset looks goofy on the rear. On the front the wheel rubbed the control arm.
http://www.o-com.net/69/2.JPG
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
