Old 07-08-2006, 12:53 PM   #1
chevroletman19712001
chevroletman19712001's Avatar
Exclamation big block to saginaw 3 speed
how much needs to be done to bolt up a big block to a factory straight 6 3 speed tranny. can the smaller clutch handle a mild 454, if it will bolt up? I kinda doubt ill ever get around to doing this, with todays current gas prices, but i just want to know if i could if i had the chance.
71 chevy longhorn 1 ton
79 chevy straight 6
79 burb 454
91 silverado 350 TBI
and a few others that my brand loyalty wont permit me to post. Eureka Boys!!!!
chevroletman19712001 is offline   Reply With Quote
Old 07-08-2006, 04:33 PM   #2
magnethead
7000 #'s of american IRON
magnethead's Avatar
Re: big block to saginaw 3 speed
bellhousing is probably different, along with the clutch you mentioned. Not sure if a big block clutch could be put on.
magnethead is offline   Reply With Quote
Old 07-08-2006, 06:38 PM   #3
oh well guess if i ever did do the swap id just use the turbo 400. thanks for the advice i didnt even think about the bellhousing being different i figured they were all the same. i just knew the v8s had larger clutches.
79 chevy straight 6
79 burb 454
Old 07-08-2006, 06:52 PM   #4
Kurt L
Kurt L's Avatar
i think that all you have to do is have an 11'' clutch,flywheel and it'll all bolt up.bell housings are the same.unless you go from full bell to half a bell housing.thats the only diff i can think of.oh yeah make sure your clutch is course splined.
Kurt L is offline   Reply With Quote
Old 07-10-2006, 06:29 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
There is nothing different from the 3 speed bell to a 4 speed bell for a truck. I did this swap years ago, but I used a muncie M22 (passenger car trans.) and the 6 cyl bellhousing. I wouldn't recommend putting the 3 speed behind it though. If you do, I wouldn't abuse it much.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
